1998 silverado slow bag project
Glad to see your starting on the frame! Tho i wouldnt have cut the center out until the top plate was welded in... But as long as the frame didnt sag your all good!
Does this sound like a good "Order of Opp's"?
-Rais Gas Tanks
-Watts Link
-Crazy Lift Setup (Im working on it)
-Tank/Compressor/valve Mount assembly
- Then rip the Leafs and Link it!
I'm thinking maybe the rear of your frame got pulled up somehow when you welded your notches in. You're sure you bed was set on correctly in the right holes and everything? If so, then it is probably the frame. It's going to be hard to get that frame back to normal. I'm sure street metal ben has some input as well. maybe how to fix it. I see this as an opportunity to start a full back half haha. anyways good luck.
Where are you measuring from and was everything level when you measured? does it look like that on both sides? the exact same gap and all.
If I were you I'd go over and check everything out. It could be a simple fix like the bed not set down in the right position. or it could be from welding your notches in. Honestly I am not there to know what was done so its hard to judge just from the picture. I'd just go through observing everything carefully and try and figure out why the bed is like that.
