help set up amp plz
jarrius
So i just got a Soudstream Tx.1 2000d in and it has WAY more adjustments on it then the amp i have used befor does. so befor i hook it up and mess every thing up i figured it would be a good idea to ask and see how to set up LPF HPF and all that on the amp. i do know that every one says BASS BOOT= off but its the LPF and HPF i need and the gain because i dont have a DD-1 or any accus to it and the audio shops around me still do it by ear or say turn it up all the way (wich is weared) so here is the specs for the amp (the ones i figured you would need) so please help so i dont blow something up
Channels/Class 1 ch. Class D
RMS Power 4-Ohm 750
RMS Power 2-Ohm 1,300
RMS Power 1-Ohm 2,000
Input Sensitivity .2-6V
THD (4-Ohm power) 0.30%
Frequency Response 10-220Hz
S/N Ratio (4-Ohm power) 83dB
Damping Factor (100Hz) 143
Channels 1&2 HPF or Subsonic 15-50Hz
Channels 1&2 LPF 40-220Hz
Bass Boost 6/12dB, 55Hz
Recommended Fusing 200
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
are you running it to those jl 10's? or the audio que's?
thats going to be for the AQ's when i get them in. i was thinking about hooking up the JL's to it at 4ohm's but i probly wont becuase i dont want to hurt them there going to go in the wifes car when my build is done and hers started
141 on music.
i do have a volt meter and i should have access to a clamp meter
and hmm there is a custom shop not to far away that has one. i may be able to use theres just has to ask
141 on music.
Set gain with dd-1 or oscope, preferably. If not that, set it with a dmm - not perfect, but it should get you in the ballpark of where it should be
Set your subsonic just beloe box tuning. I set mine by playing a 50-10hz sweep and adjust my subsonic until the subs will move as much as they can without mechanical damage
Set your lpf to between 60 and 80hz. I like mine set closer to 60 or maybe 50, but that is all personal preference
Bass boost all the way down
If you don't even have access to a dmm, you could do it by ear. You just need to know what you are listening for. Play a 40 or 50hz tone and turn the gain knob up until a slight harshness in the signal is heard, then turn it down until that goes away. If you know what to listen for, you can get it pretty close to what it needs to be
Yea i have looked at it i will just have to hit them up there not to far away.
141 on music.
Only some amps will make that noise. Only 2 amps I've ever done, and none of the ones I've owned have made a buzzing noise when they clip
Thank you every one for the help. im glad that the people here are nice and dont bash you for asking questions about how to do something. so once again every one THANKS ALOT
141 on music.
  • Who's Online   0 Members, 0 Anonymous, 1144 Guests (See full list)
