Guest MegaloManiac
all dynamat, second skin and other companies. its all a mass loader, when applied it stops the panels from vibrating and makin the sound resonating awful. It can reduce roadnoise and such. but overkill help the noise a lot from second skin on top of deading.  id type more but i am confusing myself right now. i'll come back later and help more
Guest MegaloManiac
The roofing stuff is called Peel-N-Seel and its Asphalt base. You will regret using it in the summer and winter. When really hot it melts off and leaves doodoo on the panel. and when cold it contracts and comes off. Tempreture is the biggest issue on deading 2nd is performance IMO. Second Skin seems to be the best of all. and SS is priced reasonably. Dynamat is too pricey in my books.
if u must use peel-n-seel buy a gallon of sprectrum from SS and go over the peel-n-seel with it so the peel-n-seel freezes and won't melt ever.
  • Who's Online   1 Member, 0 Anonymous, 1889 Guests (See full list)
