Couple questions, Please help.
Alright, I currently have 2 Audioque SD2.5 15's on an audiopipe 1800.1D.
My electrical problems stopped me from from being able to push these subs the way i'd like, don't get me wrong, they hit. But anyways.
I have the chance to snag a Memphis Mojo 4kw for a dirt cheap price. I'm buying it. Now, My question is this. Would it be better to build a box to exact specifications and run these subs at 4Ohm on the memphis amp, or splurge and get the HDC4 15's and put them down to 1Ohm on the memphis amp?
Also, My electric is as follows. 0G everything, minus big 3, a 15 farad hybrid cap, and I also have a small shuriken battery, I'm not sure of the size. My stock alternator is 150AMP, (02 GMC Envoy).
Which would you suggest?
As far as electrical goes, what would you suggest as to what I should upgrade to get the best out of the memphis amp?
Thanks ahead, I should be on for a while if I forgot something to help you help me please let me know. thanks.
You are nowhere near the ball park for that amp. It is a current hog.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
ditch the cap for sure
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
biggest HO alt you can find. probably two group 31 batteries for the trunk. comparable agm under the hood. 0 gauge everywhere.
  • Who's Online   0 Members, 0 Anonymous, 1193 Guests (See full list)
