1/2 6th order 4th order wall results?
markbuhler007
ok im not a begginer and i did mean a half wall the only differance between a wall and a box is the beauty pannels... i want a "box" that goes below my window line to behind my front seats like a wall... but i still want to see out my back windows and be able to be behind my b pillar so i can still compete in street beat 3 when i compete in usaci though im currently in a meca only area... the box would have beauty pannels to seal the rear hatch so the bass wave doesnt get trapped behind the box... im looking at 4th firing forward maybe up if the numbers work out... ie where i need help
so like my guess, a box that stretches from the front seats to the back of the hatch no higher then the bottom of the back window. that is still just another massive box. as far as sealing off the hatch with beauty panels making a difference i don't know.
what you need to do is figure out what subs your are gonna be using then check to see if you can fit a 4th order correctly built for the sub to fit. from there i would test it then do the beauty panels and test it again to see if there was any sort of gain on the mic.
as for firing foward or up i would say up with the port closer to the back window. the way the hatch lid slopes and the port firing off the back window could potentialy help direct it all toward the windshield(mic).
if you gave measurement more people would be able to help out more.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
my current box is 6 cubes net after disp on 2 mtx 9515s sub up port up both angled to follow the roof line... Id be useign the sameish subs there getting sent to psi getting lighter cones carbon caps stiffer spiders and bigger 8 layer coils 2.5k rms daily id be putting 10 to 12k to them
i think he means something kinda like this
http://www.youtube.com/watch?v=km3hzdLlUBk&feature=channel&list=UL
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
no seats out box formed to the rear just like a wall but only cut in half...
no, seats out box formed to the rear below the back window and it would look just like a wall but only cut in half...
^^^ tried to make it sound better, dont think it worked.
so we do understand what it is you looking for and what would be helpful is a list of what your using and max dimension for the box.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
wood front, back,top, and sides, fibreglass floor molded to the car, where the rear seats were.
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
yes, kinda like that but even in that vid the guy was saying he wants to use a plexiglass window to seal it off from the back.
unless the box is sealed off from the back half of the cabin. this would give it the same affect as a wall since it would be sealed off from the back.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
http://www.stevemeadedesigns.com/board/topic/151752-mega-cab-4-18s-in-a-4th/
unless the end result is something like this it is not a wall but is a massive box laying across the back of the car from the front seats to the back of the car.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Thats exactly what i want to do... or a full wall top half made of plexi... but due to the cost of plexi im looking to do somthing pretty similar to that box in the vid!
i would say you could do a 4th order with a pair of 10s or 12s maybe but 4th order take up a lot of space. 2 beffy 8s in a 4th order should work. people that can actually tell you if you could do a 4th order will need the max dimensions for the box though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 6689 Guests (See full list)
