How much airflow does your amp get? Some amps give off some heat at 'idle' and if it doesn't get any cooling, it could certainly build up heat.
I doubt wiring would cause anything if the volume is as low as you are describing. But I'll ask anyway: How are you wired? Have you double-checked with a DMM? And have you checked all connections?
One of my grounds might be sketchy. I got one of those stupid ass stinger 0-gauge connectors (Ones that don't crimp. Just the allen wrench type screw) that wasn't completely flat on the connection. I'll be replacing that tomorrow to see if that fixes the issue. It doesn't get much airflow They're on the trunk liner (Really thin carpet-type stuff. You know.) so that could be a definite possibility. Up in the frozen north, the one works like a dream till it gets warmed up... Then it get's fuckin' toasty.
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
some amps get hot if they "idle" as odd as it sounds itll stay cooler as you play it haha your also at .7 not 1 ohm
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Fi D1s read .7 So your subs are probly paralled ( .35 per sub then series togeather giving you .7
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1155 Guests (See full list)
