WillPwn4Food Posted November 23, 2012 Report Posted November 23, 2012 I recently just acquired 2 FI BTL N2's and 2 Planet Audio BB2400.1's. One amp ended up being defective so I'm getting it replaced. In the mean time, I'm running the BTL's (Dual 2's) on 1 PA (Wired to 1 ohm. Amp is 1-ohm stable. Yes, I realize with the other amp I'll have them wired to .5) Well right now, I'm having issues. When driving around town banging on it, it's fine. But just today I went on a longer drive (2 hours to my hometown) after about 30 minutes, the amp went into protect and was super hot. I had the bass knob turned almost completely down. No voltage drop, hardly heard any bass. What things would cause it to overheat over a long period of time but not around town? Subs were not hot. Still room temp. It's just the amp. Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus.
Truconcept Posted November 23, 2012 Report Posted November 23, 2012 hows your grounds? rawr bear metal **actin bad like a kid at six flags**
n8ball2013 Posted November 23, 2012 Report Posted November 23, 2012 if you have two dual twos on one amp its impossible to be at one ohm THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
C-Fizzy Posted November 23, 2012 Report Posted November 23, 2012 I'm guessing right now you're at .5 ohms. That amp isn't .5 ohm stable under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
CortezDTV Posted November 23, 2012 Report Posted November 23, 2012 It either at .35 1.4 or high as fuk lol SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
__d_a_v_i_d__ Posted November 23, 2012 Report Posted November 23, 2012 wiring fail at your part caused you an amp. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
KnockinthaStreetzof608 Posted November 23, 2012 Report Posted November 23, 2012 I'm guessing right now you're at .5 ohms. That amp isn't .5 ohm stable mine kept on without thermal at .5 nominal load but idk maybe because the amp never dropped below 14volts and had fans installed CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
Guest Posted November 24, 2012 Report Posted November 24, 2012 those amps are made in the same buildhouse that boss is. plus you're wired super low. im not surprised your amp got hot, etc.
CortezDTV Posted November 24, 2012 Report Posted November 24, 2012 Itsnot ..5 Fi/aa coils are. 7 or 14.... and to me their is a big different in running. 5. And. .35 SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
WillPwn4Food Posted November 24, 2012 Author Report Posted November 24, 2012 Awh snap. I'm pretty sure I just had a dyslexic moment. They're dual 1's. So it's wired to 1 ohm right now. And it was going into protect at an almost unhearable volume. It's fine at a high volume for 15 20 minutes. Same as if I have the volume super low... After about 20 minutes it goes into protect. The first amp was DOA. Never got to see power even. As well, I replaced all of the speaker wire today, so I'm positive they're wired correctly to 1 ohm. (Replaced crappy 12awg kicker wire with 10awg knukonceptz) Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus.
