OrzechNJ Posted November 25, 2012 Report Posted November 25, 2012 whats up guys... so today I installed another set of t2's in my front door and I switched on the active mode on my deh-80prs.. When I was setting up the hu for no reason suddenly the mid-range speakers in right door started to pop like crazy.. it happened over 30min after I turned everything on .. I double checked the wiring and all + go to + and all - goes to - .. what could be the reason ? I plugged out the RCA's from the amp and it was doing the same thing.. is it possible that amp got bad ? the mids are plugged on rear channels and tweeters on the front.. and like I said only the mids on right door was doing it.. Ive done short video and I will try to post it later when I get home sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
finkster Posted November 25, 2012 Report Posted November 25, 2012 did you check that your wire run wasn't shorting to ground? are the speakers bad now that they are popping? DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
OrzechNJ Posted November 25, 2012 Author Report Posted November 25, 2012 shorting u mean touching ? I dont think it was.. as soon as i turn the HU on the speakers just keep jumping.. when it happened I tough somebody was knocking the door lol volume all the way down and it keeps doin it .. the other set I put today is brand new.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
finkster Posted November 25, 2012 Report Posted November 25, 2012 unplug the rcas and see if it still pops. if you have a dmm read the resistance of the wires at the amp. One of my speaker wires shorted to ground one time. somehow a loose screw laying sideways under the carpet (dunno how i missed it) sliced through one of the wires shorting it to ground. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
xx1 Posted November 25, 2012 Report Posted November 25, 2012 same thing happened once to me, in my case one speaker terminal was touching the window rail and it cause that short. audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
ric006 Posted November 25, 2012 Report Posted November 25, 2012 sounds like bad rcas cheap ones tend to do it
OrzechNJ Posted November 25, 2012 Author Report Posted November 25, 2012 i got knukonceptz RCA's and I mentioned before that I plugged them out and same thing happens.. I plugged out one of the speakers and it kept doing it.. it got dark and cold now and I didnt really feel like work on it now .. I will check the terminals 2morrow .. if u think that it could be some other reason, im open on any advice!!! sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
OrzechNJ Posted November 26, 2012 Author Report Posted November 26, 2012 Idk how this could happen but the amp is bad... I plugged out all speaker wires and it does the popping only on right rear channel... I checked them one by one sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
