Subwoofer Box Plans Wanted--TWO FI SSD 18s in 1999 4dr Tahoe
62caddy
Hey everyone!
I just scored a slammed '99 2wd 4 door Tahoe that I want to put a couple of 18s in. I wanna go with two FI's SSD series 18s, each powered off of one Rockford T10001BD (one amp per sub). I've read that RE's box calculator is crap, and that Torres is the way to go. However, I am NOT very computer savvy and would rather just give someone $20 to throw together a set of plans with cut sheet for this box. I will go out later today and take measurements of the cargo compartment (I'm nearing the end of my lunch break, but wanted to throw this out now). I have no problem with the woodworking portion, but the computer portion is what's stumping me. FI recommends 6-10 cubes @ 33 hz per sub, and displacement per sub is 0.22 cubic feet. My initial thought is slot ported, but I will build whatever would be best for these subs. Also, I plan to use 3/4" MDF doubled up for strength, so 1.5" wood thickness. This box will not be light-weight by any means.
Let me know if you're up to make a quick $20 to make and e-mail me the planz!
Thanks,
Rick
*2004 GMC Yukon Denali, black on black 24s, stock Bose Luxury system.
*1999 Chevy Tahoe 2wd 4 door, Ford Earth Metallic paint, 6/7 drop on 20s ***System In Progress!!***
*1964 Chevy Nova Wagon---bagged, custom paint, Dakota Digital, custom leather seats, and much more!
*2004 Honda Ruckus (yellow), low, loud, and stretched!
Oh, and it is an OBS (old body style) Tahoe, so everyone knows.
My bad forgot you said you'd take measurements. But post pics of the hoe I have one myself I'd like to drop
Alpine 9884
RF T2 comp set up front
The Epicenter
2x RF T10001bd
2x Sundown sa-15 t-line
Big 3
Smd DD-1
Hey man,
40" deep (tail gate to top of back seat), 48" wide (between wheel wells), and I'd like to have the box 26" tall MAX. I want the port facing the rear and the subs up-firing if possible. I'll throw up some pics tonight!
Thanks!
So here is a suggestion:
Enclosure Specifications:
Fb = 33 Hz
Vb = 14.5 ft^3
External Height = 25 in
External Width = 42 in
External Depth = 34 in
Port Width = 35 in
Port Height = 5 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 42 x 34
Left & Right Sides = 32 1/2 x 22 3/4
Front & Back = 42 x 22 3/4
L Port Internal Assembly Parts:
Front to Back = 15 1/2 x 36 1/2
Port Left Side Assembly:
15 1/2 x 5
Port Right Side Assembly:
15 1/2 x 5
Assembly guide (generic dimensions):
Let me know any questions.
Joe X, thanks for that! It's basically exactly what I was after. Everything is very straight-forward, except I'm having trouble visualizing how the port is layed out. Is it open on the back inside the box? And to make sure, the port dimensions are 36.5" wide x 15.5" deep x 5" tall, right? Are those measurements for the inside of the port or outside of the port?
And here's the truck the box will be going in :)
Box is to high IMO. I've done multiple boxes for 2 18s in my hoe an the ones that were high failed.. Keep it around 20 high
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
The port is 35x5 as stated at the top, the dimensions of the cuts are made the size needed for the parts to assemble.
Regarding the comment above, the box can be downsized to 22.5 Minimum height (6 cubes per sub) which is not very different to 25 in. Anyhow it would be nice to know the height to the roof in your vehicle.
From the cargo area to the head liner is about 38-39"
I appreciate all your help in this!
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
