Sundown & Rockford amp guts question?
FosgateLife
Doesn't fosgate use rails?
Thats just in the BRT amps. Boosted rail technology. I think anyways?
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Those wires are usually from the output section to the speaker terminals because the output section ends up on the other side of the amp. Depending on how the amp is designed it may not need them, most Korean amps make use of one set of them (including Sundown, Nendo, DC, etc.)
I'm gonna hate
im willing to bet tony candela can answer this if hes not too busy. You probably wont understand him( hes a bit of a nerd :D ) but he may know a thing or two about the design. lets see if he finds this.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If you just place traces on the PCB to the speaker terminals from the output section you don't need wires, that's assuming the output section is close enough to a logical place for speaker terminals. Since all of the I/O is on the long side of the Power series amps it only makes sense that the wires aren't necessary.
I'm gonna hate
Power 2500
AQ3500
EDIT
All power supplies have "rails" all 12v amps have power supplies. Fosgate's rails are special because they are "boosted" now shutup and buy a PBR amp!
I'm gonna hate
I see the light! Thanks for the answer. I'm sure fosgate life will chime in and say thanks as well.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
CA Auto/ Electric Big 3
Xs power d680 in parallel with new group 65 stocker
Soon to come another d680
Rockford Punch 6x8 3 ways in the front, Rockford Punch Pro 6.5s in the back
Soon to come Pioneers all around
Focal Solid 4 Speaker Amp
Kenwood KDC-X896
Memphis Line Driver
My build log: http://www.stevemeadedesigns.com/board/topic/160368-03-f150-king-ranch/
Youtube: https://www.youtube.com/user/LabAudio502?feature=mhee
That diagram made alot more sense!!! That question has been on my mind for a while ao thanks to you who helped with the answer!!
Just one more question, is either of the 2 better? Or does it not matter what way they are set up? I imagine they are the same
It really doesn't matter, just one of a thousand things going on in either of those amps. It all comes down to the design which is dictated by another thousand things. I wouldn't give whether an amp has copper spaghetti inside of it or not any thought when buying. Look at some of Linear Power's "messes" inside amps and they are the best amps I have ever heard.
I'm gonna hate
  • Who's Online   0 Members, 0 Anonymous, 1144 Guests (See full list)
