It's been a while since I did keyless entry. I ended up getting 5 wire door actuators instaed of 2 wire. Can I still use them with teh Autopage 601 that i also got. I believe the Autopage is a simple reverse polarity system.
TIA
Rolex you sicken me.
Just let me finish my pie
~ Juice
You can wiring the actuator to your alarm...you need only the 2 wires that move the actuator in/out (green/blue wires of actuator) and you need also 2pc's spdt relay's.
because your 3pin plug can not move your actuator directly.
your gonna need 2 relays per actuator, one for lock, one for unlock, you should only need the lock/unlock lead wires from the actuator
follow this diagram for each
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
  • 8 months later...
