Fourth Order Wall
Bdurb
So i plan on starting my new build, and this time i want to do a fourth order, im still learning a lot but i have sucessfully walled a car before, well pretty successful. anyways
2 Obsidian 15s
2 audiopipe 1500s
was debating the different ratios and tuning. im not concerned about being competition worthy as much as i am pounding the lows.
here was my idea, constructive criticism is highly welcome.
5:1 ratio, 4 cu feet sealed, 20 ported. 40hz tuning. is this logical? should the ratio change? i have a jetta wagon with the room to allocate this.
My old Build Log!
http://www.stevemead...der-in-a-jetta/
Two Obsidian 15s V2
Two Audiopipe Apsm 1500s
Fourth Order Wall
TEAM CLEARLY LOUDER
TEAM OBSIDIAN AUDIO
Cone area is going to be more vital than anything. The power you are working with is fine.
The space you are trying to consume with 2 15s isn't normal by any means. 4 15s, even lower quality 15s would occupy that amount of space better. Say 8 sealed 16 ported... Edited for bad math.
Being that it hasn't been done yet, I can't tell you not to give it a shot... But if you approach it, you should have the mindset that it probably isn't going to work out the first time, or maybe even the second of third.
ok i really appreciate your honesty. so now for the suggestions. lower the ratio to a 4:1, 3:1 or 2:1? and so i understand, you're saying the response probably wouldnt be that reat?
My old Build Log!
Two Obsidian 15s V2
Fourth Order Wall
TEAM CLEARLY LOUDER
TEAM OBSIDIAN AUDIO
biggest i go would be the 3-1, 4 sealed, 12 ported for 15s, that is the biggest i would go.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
  • Who's Online   0 Members, 0 Anonymous, 2783 Guests (See full list)
