Mids and highs amp keeps shutting off
Mojo Man Miller
i got a problem that i thing i know how to fix, but in not sure lol. i have all my 3 amps on my 2nd battery (kinentik 2000) and it sounds fine when its all the way up but when the bass stops in the song, my door speakers shut off for a second... i have my tweeters hooked up to my head unit and they keep playin... my best guess is that the sub amps are drawing so much power away from the other amp that once the bass stops, my mids and highs amp has all this extra power rushing to it all of the sudden that it more or less doesnt know what to do so it sputters for a second. does anyone know if a capacitor on just my mids and highs amp would help this??
How many watt´s RMS do you powering? Did you use you send your signal to the bass and mids amp and use a internal high or low -pass as crossover?
"in the abundance of water, the fool is thirsty" Bob Marley
Low voltage...or high heat, caused by low voltage....
Check to make sure all the power connections to your amp are tight...including ground and all terminals along the way.
Eclipse cd7000
i have 2 1000.1's that do 1200 watts and a 50.2 that is doin 75x2 so pretty much 2550 watts all in all...and on my mids and highs amp i have the high pass filter on
All on stockalt, underhoodbatt and the Kinetik.
Charge your batt´s both to full tilt and try it again. For the power you run your car can use a H/O alt.
Or you have one of those weired ampprobs with the highpass.
u got the pr50.2? what size wire going to it? i ran 4guage to my 150.2 and ran it at 2ohm stereo
do you have big 3 done? i like caps n what knot, but when i just had a cap in the car it ran my front battery dead
memphis amps tend to pull the power 2 1000's is around 240amps or mine has 4 30amp fuses, dunno if the new one has 4 40amp fuses or not
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
  • Who's Online   0 Members, 0 Anonymous, 858 Guests (See full list)
