FosgateLife Posted December 3, 2012 Report Posted December 3, 2012 Amp is American Bass vfl 120.1 Is it possibel to wire 2 Dual 4 ohm subs down to 1 ohm, and hook them up and still get full power??? Amp has 2 sets of + and - . if i wire them to 1 ohm how would i wire them to the amp since there will only be 1 set of + and - and my amp needs 2 sets? im confused 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Trey_Dog650 Posted December 3, 2012 Report Posted December 3, 2012 Your amp doesn't need 2. They are just there for ease of wiring. Just pick a terminal and be done 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
ChevyBoy95 Posted December 3, 2012 Report Posted December 3, 2012 yes. the two + and two - on the amplifier are bridged so in reality is is one + and one - with two spots to insert wire. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
FosgateLife Posted December 4, 2012 Author Report Posted December 4, 2012 Your amp doesn't need 2. They are just there for ease of wiring. Just pick a terminal and be done so will they be getting full power as if they were wired with 2 sets? 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Trey_Dog650 Posted December 4, 2012 Report Posted December 4, 2012 Yup 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
Polarbear Posted December 4, 2012 Report Posted December 4, 2012 is it bad to bridge an amp does it over work it to much? i know it sounds like a dump question but im new at this 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
Blackedout Posted December 4, 2012 Report Posted December 4, 2012 is it bad to bridge an amp does it over work it to much? i know it sounds like a dump question but im new at this You can't bridge a mono block amp. For a 2 channel/ 4 channel amp it is usually okay to bridge a pair of channels at 4 ohms. Doing so makes each channel see a 2 ohm load for maximum capable output. If the 4 channel amp is one ohm stable, it would be okay to bridge at 2 ohms on a pair of channels. Trunk Build Log
Polarbear Posted December 4, 2012 Report Posted December 4, 2012 i have the hifonics colossus.. just some people say it over works the amp but ima wire it up bridged at 2 ohms. 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
Blackedout Posted December 4, 2012 Report Posted December 4, 2012 i have the hifonics colossus.. just some people say it over works the amp but ima wire it up bridged at 2 ohms. It's no different than running the amp at 1 ohm. You'll be alright If you have the electrical to support it. They are power hungry amps. Trunk Build Log
Polarbear Posted December 4, 2012 Report Posted December 4, 2012 thanks man i do i got a 240 mechman h/o alt and a d3100 all ready to hook up just waiting on my second skin to get in! 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
