Does port volume matter?
Wiseracing2
Lol, its an important word!!
Are you from the Bay Area or the Bay Volume????? :rofl:
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)
2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)
2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)
Checkout our build and videos !! : ) 150+ Trunk Build Log itsgordy1 youtube channel (click for Hairtricks)
Smith's Custom Seats
Martinsburg, PA
(Second Skin Dealer)
The port volume range of 12-15 sq inches of port per cube was found by trial and error. We can generalize it and say that the most effective boxes fall in this range. Keep in mind that it is only a guideline.
Advantages of less port area:
- More power handling.
* Note: This assumes that the size of the box is within an acceptable range of the driver you are using.
Haven't figured out the advantage of more port area yet. Someone else might be able to elaborate on this.
You are correct when you say the port areas you listed as being a guide line. Usually a 12 to 14 sqin per ft for an aero port and 14 to 16 sqin per ft for a square is pretty close most of the time. Port area is based off of how many drivers are in an enclosure ,what the port is tuned to and the xmax of the speaker.
you can also use the port area to manipulate the back pressure in the enclosure, therefore affect mechanical power handling. however, this can also affect thermal power handling as well. more movement = more air circulating in the motor of the sub and a cooler operating sub, but less mechanical power handling. there is a very fine line there though, that can be easily fucked up.
i am speaking in general though. too many specifics to go into, which would be an extremely long post.
Owner of BigAss Ports
port volume = how much internal box space the port takes up. aka displacement. 3D. cubic feet.
port area = the cross sectional area of the port. 2D. square inches.
edit: end thread. you guys fought when i just put it all into perspective in 5 seconds LOL.
  • Who's Online   0 Members, 0 Anonymous, 1788 Guests (See full list)
