elflako17 Posted December 6, 2012 Author Report Posted December 6, 2012 If the subs are DVC 4-Ohms (you didn't specify), you will of course wire them parallel to 1-Ohm but will likely measure .7 to .8-Ohms at the amp so on the math side you are at 1700 watts but again and as mentioned above by others, box rise will affect the impedance at the amp but the amps are typically 35 to 55 watts over 1700 so you can expect as close to 1700 watts as you are going get. yea i will be getting 2 dvc 4 ohms subs from Skar Audio 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
Team Maxxsonics John Posted December 6, 2012 Report Posted December 6, 2012 If the subs are DVC 4-Ohms (you didn't specify), you will of course wire them parallel to 1-Ohm but will likely measure .7 to .8-Ohms at the amp so on the math side you are at 1700 watts but again and as mentioned above by others, box rise will affect the impedance at the amp but the amps are typically 35 to 55 watts over 1700 so you can expect as close to 1700 watts as you are going get. yea i will be getting 2 dvc 4 ohms subs from Skar Audio Then you will be just fine.
elflako17 Posted December 6, 2012 Author Report Posted December 6, 2012 thats sounds good 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
