why are ther two cvr's in there?
olllld pic. i have my 4 r's in there now. so you dont think my amp will push at all. because that box is a LIL smaller than the one you designed and it hits pretty hard
3 12" Alpine Type-R's
1 Hifonics 2010d amp
the box i designed is large, will be loud, and will hit low.
basically u are only gettin 250wrms to each one of those subs. so if u get a new amp u will have twice the power over the same cone area which automatically gives u a 3 db gain. plus a larger box will also make the subs output louder.
so i say upgrade ur amp and make a new box and have fun
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
so your saying if i make the box you designed now it would be pointless?
not entirely cause itll hit lower notes better i believe. which is wut u were wanting in the first place correct?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
absolutely. so you think this amp will last pretty good for about two weeks til i get money for a better one?
no it wont be pointless. i rebuilt a box i had, changed no subs and no amps, and got more output from it. he's saying when you rebuild it and add more power, you're going to be even louder. an install is 80% build, 20% equipment
the amp will be ok to hold you over imo, just dont strain it to keep the signal clean. dont wanna damage your speakers while you wait for the new amp :(
it will work and it will prolly be loud just because of cone area but all im sayin is it could be alot louder
go ahead and wire em to 2 ohm keep the gain below 1/2 and u should be fairly satisfied but with a new amp ull be even happier
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
thanks alot from the both of you. i learned a lot, well im going to make the box today and ill let you know how it turned out. maybe some vids? or build log of just the box?
amen
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 880 Guests (See full list)
