the second port length for an L shaped port. i figured 32.8hz was low enough but u can get it lower if u add another piece of wood to make the port longer
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
cut the wood like it says to cut cause that will give u a perfect box
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
yeah, that calculator takes off wood displacement on the edges. so it'll all fit right together.
and yeah...2 sheets of MDF should do the job right. make sure to make the most efficient cuts
Edited by ExpoSport
well i made the box today and every cut was exact but for some reason the port height came out to 4 3/4 instead of 4.5, well sorry for not haveing a build log. cam died....but it sounds loud!! one problem....it hits high notes and goes into protect....is there anything i can use to keep the subs/amp from hitting high notes?
3 12" Alpine Type-R's
1 Hifonics 2010d amp
  • Who's Online   0 Members, 0 Anonymous, 1063 Guests (See full list)
