So im having a personal problem... I currently have a 2001 Taurus and 2 15" Fi n2's in the trunk. I have subs facing into cabin (pull down seats) and port facing driver's side of vehicle in the trunk. Well the box is so big it's nearly sealing the port in the trunk(as in no air movement around edges of box except in the trunk.) I can't make the box smaller. It's already as small as I can make it. Would it be beneficial to run 2 12's and have subs AND port firing into the cabin for spl? Any and all input welcome. Thanks. As well if anyone has any input on 2 12's that are around 2kw each that'd be great. Other option would be 1 15" = 4kw?
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
I would go with 2 12s sealed from trunk and firing into cabin. But thats just my opinion because i like the way that looks. You could do 1 15" but 4k is a lot for one n2 (n3 would be better) and 2 12" have more cone area than a single 15
Yes the 12's would allow a smaller box and having everything forward and sealed is usually loudest. Maybe some mayhems since you already have fi
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
if its that big finish sealing it off. duh
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Nevermind I miss read it. This is one of those times where a proper design isn't possible for your gear.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You could always just move the fucking port.
:peepwall:
2005 Dodge Ram 1500 Regular CabPioneer MVH-P7300Orion 800.4Planet Audio Big Bang series 6.5 componentsJL G17002 Diamond Audio D610D4's
Build log
women drivers no survivors
@n8 I realize that. Hence why I asked if 2 12's would work better. And I couldnt move the port anywhere other than straight back or to the other side of the trunk. Regardless, it'll still be pretty much sealed off.
Neither do morons
yeah in your case it would be a better idea to downsize your woofers in order to get any airflow. You could recone your 15s to 12s.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1115 Guests (See full list)
