Question on connecting 2 batteries.
Hey guys im finally starting on my first "big" build......for me anyways.....and Im planning on running 2 batteries. I have a yellow top under the hood and was thinking about getting a kinetik hc 800 for the trunk area. I read somewhere that to link batteries together they have to be identical or you have to use an isolator if they are different. If I put an isolator wont the power for the amp be pulled only from the rear battery? If so the hc-800 will not have nearly enough power for my set up. Sorry for the noob question in advance but im new at this.
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
The isolator only disconnects the 2 batteries when the vehicle is turned off to keep the lower charged battery from discharging the better... when the isolator is activated it allows both batts to work together... basically its a high amp relay...
so once the car is turned on it allows the batteries to work together and when not running keeps the front batt from draining correct?
Skyhigh wire
some batteries
ok so im hearing two sides haha....I thought that yellow tops were agm batteries am I wrong?
Skyhigh wire
some batteries
  • Who's Online   0 Members, 0 Anonymous, 2202 Guests (See full list)
