fiberglassing a rear deck
sooo im thinking eventually of fiber glassing my rear deck in my integra for like 2 sundown neopro 10s or some similar 10 inch pro audios
good or bad idea?
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
I personally wouldn't do it, rather put the 10's on the doors instead, and unless you completely seal off the reardeck, the sub is going to mess them up.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Cons:
1. Windowshoppers
2. Overpowering rear fill (especially if more than hu power)
3. Like Omega said, the woofers will turn them into passive radiators! (unless it's more of a fiberglass box)
Pros:
1. Looks great.
Personally, I would do it for a show car. However, I wouldn't do it for a daily driver. If you need to, search up someone stolen stuff threads. That just might change your mind :P
I did something similar to this, but with just a set of 6.5 comps. I just made a cutout of the shape of the rear deck and glassed onto that, so my woofers wouldn't destroy the midbass drivers.
Just seems like two Neo pro's would be some mad hefty rear fill, unless you've got a strong front stage.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
probably pass then and just end up running some pa speakers in my door, thanks everyone
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
