Noel989 Posted December 27, 2012 Report Posted December 27, 2012 They're not as loud because the vocals are not clipped like your normal tyga CD lol Well its stll clipped no matter what he does to them I'd rather have a clipped -7db signal than a clipped 0db signal. -7db -0db is not clipped. and when you normalize a song below 0db its no longer clipped. at least with any song ive rebassed. Well then you need to go back and study more just cause you can't hear hear doesn't mean its not their Once a song is clipped theirs nothing you can do to unclipped a song Unless you have the origal file of the studio were the song was made and samples they use I can make you a track that when you check for clips on any program you won't find any but the song will be clip to it's max All you probably doing it making it quieter smaller wave then audacity doesn't shown correct waveform then? What do you mean correct waveform? If the original track is clipped it will forever be clip If you make the wave smaller thenyour bringing the volume down and and so will the distortion I think decaf said don't quote me on this though That the clipping indicator on audacity is set at 0db so anything higher than that will so clipping even if it's not then audacity must auto-repair waveform when your normalize because none of the waveform is clipped (peaks cut) on any of the songs ive norm'd Your not understanding Even if the wave doesnt show it could still be clipping if the original song is clipped it downstream matter what you do it will still be To fully unclipp a song you need 1 or both of th following 1. If the promblem was in the mixin or mastering phase thenyou need to mix or remaster the original project (which you don't have unless you work at the studio that's recorded at) Or 2. If the clipping was from samples or intruments Use then you need to find that channel/track and redo it And then mix and master Like I said before If you want I could make a Song that shows no clips but it will sound like shit wenh you listen to it Also read post #9 on this page Build Log - http://www.stevemead...-cruiser-el-pt/
Tito DeLatorre Posted December 27, 2012 Report Posted December 27, 2012 They're not as loud because the vocals are not clipped like your normal tyga CD lol Well its stll clipped no matter what he does to them I'd rather have a clipped -7db signal than a clipped 0db signal. -7db -0db is not clipped. and when you normalize a song below 0db its no longer clipped. at least with any song ive rebassed. Well then you need to go back and study more just cause you can't hear hear doesn't mean its not their Once a song is clipped theirs nothing you can do to unclipped a song Unless you have the origal file of the studio were the song was made and samples they use I can make you a track that when you check for clips on any program you won't find any but the song will be clip to it's max All you probably doing it making it quieter smaller wave then audacity doesn't shown correct waveform then? What do you mean correct waveform? If the original track is clipped it will forever be clip If you make the wave smaller thenyour bringing the volume down and and so will the distortion I think decaf said don't quote me on this though That the clipping indicator on audacity is set at 0db so anything higher than that will so clipping even if it's not then audacity must auto-repair waveform when your normalize because none of the waveform is clipped (peaks cut) on any of the songs ive norm'd Your not understanding Even if the wave doesnt show it could still be clipping if the original song is clipped it downstream matter what you do it will still be To fully unclipp a song you need 1 or both of th following 1. If the promblem was in the mixin or mastering phase thenyou need to mix or remaster the original project (which you don't have unless you work at the studio that's recorded at) Or 2. If the clipping was from samples or intruments Use then you need to find that channel/track and redo it And then mix and master Like I said before If you want I could make a Song that shows no clips but it will sound like shit wenh you listen to it crappy sound quality isn't clipping haha.
Noel989 Posted December 27, 2012 Report Posted December 27, 2012 They're not as loud because the vocals are not clipped like your normal tyga CD lol Well its stll clipped no matter what he does to them I'd rather have a clipped -7db signal than a clipped 0db signal. -7db -0db is not clipped. and when you normalize a song below 0db its no longer clipped. at least with any song ive rebassed. Well then you need to go back and study more just cause you can't hear hear doesn't mean its not their Once a song is clipped theirs nothing you can do to unclipped a song Unless you have the origal file of the studio were the song was made and samples they use I can make you a track that when you check for clips on any program you won't find any but the song will be clip to it's max All you probably doing it making it quieter smaller wave then audacity doesn't shown correct waveform then? What do you mean correct waveform? If the original track is clipped it will forever be clip If you make the wave smaller thenyour bringing the volume down and and so will the distortion I think decaf said don't quote me on this though That the clipping indicator on audacity is set at 0db so anything higher than that will so clipping even if it's not then audacity must auto-repair waveform when your normalize because none of the waveform is clipped (peaks cut) on any of the songs ive norm'd Your not understanding Even if the wave doesnt show it could still be clipping if the original song is clipped it downstream matter what you do it will still be To fully unclipp a song you need 1 or both of th following 1. If the promblem was in the mixin or mastering phase thenyou need to mix or remaster the original project (which you don't have unless you work at the studio that's recorded at) Or 2. If the clipping was from samples or intruments Use then you need to find that channel/track and redo it And then mix and master Like I said before If you want I could make a Song that shows no clips but it will sound like shit wenh you listen to it crappy sound quality isn't clipping haha. Really thats all you got you got? We aren't even talking about sound quality here were talking about clipping You just don't want to admit you can't unclip a song with your audacity normalizer Claiming to fully unclip with a normalizer or whatever it's called or you use is like those that say I do 190 DBS with 1 Sony xplod Build Log - http://www.stevemead...-cruiser-el-pt/
Tito DeLatorre Posted December 27, 2012 Report Posted December 27, 2012 Noe; then explain to me why audacity fails to show waveform distortion, because that what clipping is. at least in this stage of sound reproduction. and if it doesn't show clipping, than its not clipped, it just sounds like shit lol
Noel989 Posted December 27, 2012 Report Posted December 27, 2012 Dude I already told you that clip thing that's on audacity its a 0db marker anything past that its clip don't beleive me decaf wrote it on this thread. Also Read post #9 on this page And Im not bashing on you I just want you to understand you can't fully unclip a song even the biggest name on boosted music decaf has said it he can't and that their some on his He and you just make it quieter so you can boost while still sounding good Build Log - http://www.stevemead...-cruiser-el-pt/
Noel989 Posted December 27, 2012 Report Posted December 27, 2012 Noe; then explain to me why audacity fails to show waveform distortion, because that what clipping is. at least in this stage of sound reproduction. and if it doesn't show clipping, than its not clipped, it just sounds like shit lol It will show clipping on the origal file But it won't show clipping on audacity Build Log - http://www.stevemead...-cruiser-el-pt/
Truconcept Posted December 27, 2012 Report Posted December 27, 2012 Claiming to fully unclip with a normalizer or whatever it's called or you use is like those that say I do 190 DBS with 1 Sony xplod i used 2 burp 192DB with 1 sony XS-L121 12" but i had it wired @ -2ohm and it was powered by my mom yelling at me **actin bad like a kid at six flags**
Noel989 Posted December 27, 2012 Report Posted December 27, 2012 :rofl: :rofl: Was it an oof day I'm sure you could've gotten to 200 Add some sundown decals for teh extra DBS Claiming to fully unclip with a normalizer or whatever it's called or you use is like those that say I do 190 DBS with 1 Sony xplod i used 2 burp 192DB with 1 sony XS-L121 12" but i had it wired @ -2ohm and it was powered by my mom yelling at me Build Log - http://www.stevemead...-cruiser-el-pt/
RooTxBeeR Posted December 27, 2012 Report Posted December 27, 2012 Noe; then explain to me why audacity fails to show waveform distortion, because that what clipping is. at least in this stage of sound reproduction. and if it doesn't show clipping, than its not clipped, it just sounds like shit lol Seriously, if your trying to troll just stop, it has been explained multiple times so far in this topic. Dude I already told you that clip thing that's on audacity its a 0db marker anything past that its clip don't beleive me decaf wrote it on this thread. Also Read post #9 on this page And Im not bashing on you I just want you to understand you can't fully unclip a song even the biggest name on boosted music decaf has said it he can't and that their some on his He and you just make it quieter so you can boost while still sounding good ^^^^^ lol On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Noel989 Posted December 27, 2012 Report Posted December 27, 2012 Noe; then explain to me why audacity fails to show waveform distortion, because that what clipping is. at least in this stage of sound reproduction. and if it doesn't show clipping, than its not clipped, it just sounds like shit lol Seriously, if your trying to troll just stop, it has been explained multiple times so far in this topic. Dude I already told you that clip thing that's on audacity its a 0db marker anything past that its clip don't beleive me decaf wrote it on this thread. Also Read post #9 on this page And Im not bashing on you I just want you to understand you can't fully unclip a song even the biggest name on boosted music decaf has said it he can't and that their some on his He and you just make it quieter so you can boost while still sounding good ^^^^^ lol Was so funny? I wanna laugh to Build Log - http://www.stevemead...-cruiser-el-pt/
