halfachubby Posted December 17, 2012 Report Posted December 17, 2012 I've got two JL 12w3v3s 4ohm 500w RMS single coil in a ported box not sure what Hz. Thinking of getting a used JBL GTO 14001 or Alpine MRP-M1000. Would "down gaining" be easy with the JBL w DMM method? It's 1500 RMS at 2 ohm some body recommended it to me over the Alpine.
Watch the bass Posted December 17, 2012 Report Posted December 17, 2012 It´s nice to have a vew more watt´s. Otherwise you need the electrical to back up this power!. 1500 watt´s are arround 150 amp´s of extra draw to your electrical system. What kind of batt´s and how many did you have in the car, did you have a H/O alt? A nicer option for a 1000 watt amp, is the Soundstream reference series http://www.ebay.com/itm/NEW-SOUNDSTREAM-REFERENCE-REF1-1000-1000-WATT-RMS-MONO-SUBWOOFER-AMPLIFIER-/150942024117?pt=Car_Amplifiers&hash=item2324d881b5&vxp=mtr for a selloutprice. Beautifull amps in class G technic, Class G combine the advantages of class AB (sound) and Class D (efficiency), only negative big as f... "in the abundance of water, the fool is thirsty" Bob Marley
jimmyjack Posted December 17, 2012 Report Posted December 17, 2012 t all started 9/28/12 I purchased my first Wrangler. A 1995 4.0 with the AX-15 5 Speed. I did a few minor things to it after I bought it but I was mainly preparing for the audio build (as stated in my signature). The one thing I did do was spend $2500 on a custom built hardtop that arrived on 12/7/12, my dad and I drove 50 miles south in the rain to put it on, in the rain... My new Kenwood head unit arrived 12/12 and so did my RF T1 4x6s both installed the same day. My center console arrived the next day and was installed right away. testking latest exam prep testking latest exam prep pmi-001 practice test pmi-001 practice test 220-701 practice test 220-701 practice test 650-393 practice test 650-393 practice test 70-662 practice test 70-662 practice test 70-649 practice test 70-649 practice test
halfachubby Posted December 17, 2012 Author Report Posted December 17, 2012 It´s nice to have a vew more watt´s. Otherwise you need the electrical to back up this power!. 1500 watt´s are arround 150 amp´s of extra draw to your electrical system. What kind of batt´s and how many did you have in the car, did you have a H/O alt? A nicer option for a 1000 watt amp, is the Soundstream reference series http://www.ebay.com/...4d881b5&vxp=mtr for a selloutprice. Beautifull amps in class G technic, Class G combine the advantages of class AB (sound) and Class D (efficiency), only negative big as f... I don't have a h/o alt I'm a little new to this so I'm not sure what that is. I'm hoping to avoid extra batteries if possible, would that be possible with 1000w? I wouldn't mind replacing my battery with a nicer one, it's just a stock battery from a 99 toyota camry I think. That amp looks nice. I think it's the same one used for the bench test I had done on these. Definitely seems like it will want more than one battery though. Maybe I should've thought about that before buying two 12s lol.
ChevyBoy95 Posted December 17, 2012 Report Posted December 17, 2012 If you had a good sized XS Power Battery up front, you could run 1-1,500rms for daily. edit: h/o alt, ho alt, etc. is all High Output Alternator, i.e. more than stock output. Most are around 200+ amps. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Watch the bass Posted December 17, 2012 Report Posted December 17, 2012 Or get 2 of those, 1 under the hood 1 in the trunk http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/. "in the abundance of water, the fool is thirsty" Bob Marley
halfachubby Posted December 17, 2012 Author Report Posted December 17, 2012 If you had a good sized XS Power Battery up front, you could run 1-1,500rms for daily. Sounds good is there a guide on what battery you need for certain wattages?
Watch the bass Posted December 17, 2012 Report Posted December 17, 2012 If you had a good sized XS Power Battery up front, you could run 1-1,500rms for daily. Sounds good is there a guide on what battery you need for certain wattages? http://www.stevemeadedesigns.com/board/topic/69019-xs-power-battery-wattage-guide/ "in the abundance of water, the fool is thirsty" Bob Marley
