Rockford96 Posted December 19, 2012 Report Posted December 19, 2012 He's using .5" MDF(for low powered subs go for it). I think you can get away with 3 3" ports at 18" long, 2 sundown E10s, tune of 34.41Hz, internal volume if 2.21 after displacements. That is plenty for those subs. Pre drill every hole perfectly, to avoid splitting, and seal the HELL out of the box with silicone and make sure you've glued all the joints well. I've got this estimate assuming its firing at the B-pillar. You must have 3" of clearance from the port to the nearest obstruction. ok awesomw i took a screen shot if that lol but hey thanks alot man! I havr learned alot from you about boxes and i will seal it up great and my last box pilot drilled every hole no splittun:) ive been workin with wood since i was very you and i have always wanted to run sundown their subs and amps are bada** thanks man! Now i gotta find a sundown 1000dsa-12 after xmas:) edit: on mobile it put sa-12 in there after 1000d idk y droids r weird lol My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Rockford96 Posted December 19, 2012 Report Posted December 19, 2012 Your got 2.2gross if box is 50x19x(4/8) Even 2x 10" ported wont happen And with a shallow m/depth the sa8 are off the list Idd say 1 ported 10 Or 2 to 3 ported 8" If wan to go sealed that different story You could do 4x e10 in there on 15-2k You also need to allow room for the sub to move and if thoes mesurments are hard up against the back of the seat you'll have to take even less off the depth then you looking at a smaller net an gross again those dimensions do allow the su s to move fine and o will i e doing what cleanseirra said most likely if $$i allows My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
CleanSierra Posted December 19, 2012 Report Posted December 19, 2012 Your last message looks like gibberish. Don't text and drive dude Im not the one you want to try to troll. Just a fyi for you.
Rockford96 Posted December 19, 2012 Report Posted December 19, 2012 Your last message looks like gibberish. Don't text and drive dude my bad my phone was acting up and no way i was drivin when im behind the wheel my phones in the glovebox till i stop i would never risk a text over my life i like my life:) haha but thanks for caring man thats why i love this forum My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
jwalks Posted February 11, 2013 Author Report Posted February 11, 2013 Thanks for the info guys. I ended up getting a Kicker cvr in a spec box pretty cheap off of a friend. Ultimate low budget Lancer
bassaholicsfl Posted May 4, 2014 Report Posted May 4, 2014 For some reason, I have learned to hate you. 2001 Dodge Ram Quad Cab.
