Johnallen03 Posted December 19, 2012 Report Share Posted December 19, 2012 I have 2 American Bass XFL 12s that i need a box design for. They will be going in the trunk of my bonneville. Im just looking for a nice box other then the crappy prefab one i had for daily use. The max space i have available is roughly 38 x 38 x 17. any help and suggestions is greatly appreciated. thanks in advance Link to comment Share on other sites More sharing options...
Johnallen03 Posted December 20, 2012 Author Report Share Posted December 20, 2012 nobody? Link to comment Share on other sites More sharing options...
Joe X Posted December 20, 2012 Report Share Posted December 20, 2012 So here is a suggestion for use on rated power: Enclosure Specifications: Fb = 33 Hz Vb = 4.5 ft^3 External Height = 16 in External Width = 37 in External Depth = 24 in Port Width = 5 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2x Front = 16 x 14 1/2 2x Front Internal = 14 1/2 x 14 1/2 Back = 37 x 14 1/2 Left & Right Sides: 22 1/2 x 14 1/2 Top & Bottom = 37 x 24 Shared Port Internal Assembly Parts: 2 x Front to Back = 20 x 14 1/2 2 x Extension = 5 1/16 x 14 1/2 Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the ones inside the port, if you want to do those let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 5" of free airspace in front of it for proper operation. - Setting your amp's subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
Johnallen03 Posted December 20, 2012 Author Report Share Posted December 20, 2012 thanks alot, do you think the 45's inside the port will be needed? Link to comment Share on other sites More sharing options...
teamace24 Posted December 20, 2012 Report Share Posted December 20, 2012 I would probably tune around 35-36 hz for american bass subs i hear they like similar boxes to audioque. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
Joe X Posted December 20, 2012 Report Share Posted December 20, 2012 I have seen boxes perform great with them and without them, the fact is that if they are made improperly they can ruin the whole box. Ideally the should improve SQ and performance a bit. Link to comment Share on other sites More sharing options...
