iceman1575 Posted December 21, 2012 Author Report Posted December 21, 2012 my guess is the over clocking software . try turning it off as i bet it only nets you a couple fps anyways Already did, still throttles down. It's the Speedstep built in to the GPU. POTATO!
Neckbeard Posted December 22, 2012 Report Posted December 22, 2012 the MSI laptops are meant for gaming, which is weird that its doing that. I would get one of the lap top cooling pads like you said, and if its still doing it, Would do the BIOS thing Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
Guest Posted December 22, 2012 Report Posted December 22, 2012 have you thought about...contacting the manufacturer?
beaker Posted December 22, 2012 Report Posted December 22, 2012 I've found that 99% of the time the thermal paste from the factory sucks. I replace it on everything I buy. In fact, when I got my 470, I immediatly took it apart and replaced all of those stupid foam heat transfer pads with ceriamique. If done correctly, you could see up to a 20 degree drop in temps. Just take your time and be gentle taking it apart.
Sheena Posted December 22, 2012 Report Posted December 22, 2012 I've found that 99% of the time the thermal paste from the factory sucks. I replace it on everything I buy. In fact, when I got my 470, I immediatly took it apart and replaced all of those stupid foam heat transfer pads with ceriamique. If done correctly, you could see up to a 20 degree drop in temps. Just take your time and be gentle taking it apart. He already did this. And I do not recommend disabling speedster or anything, if it hits 100c with being throttled, I'm willing to bed it would just blue screen if you disabled it, or fry. Cooling pad, or play by an a/c vent 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
iceman1575 Posted December 22, 2012 Author Report Posted December 22, 2012 I've found that 99% of the time the thermal paste from the factory sucks. I replace it on everything I buy. In fact, when I got my 470, I immediatly took it apart and replaced all of those stupid foam heat transfer pads with ceriamique. If done correctly, you could see up to a 20 degree drop in temps. Just take your time and be gentle taking it apart. He already did this. And I do not recommend disabling speedster or anything, if it hits 100c with being throttled, I'm willing to bed it would just blue screen if you disabled it, or fry. Cooling pad, or play by an a/c vent I don't know what would be the easiest method. I'm still befuddled at the fact that a 2.2GHz quad core processor is ALWAYS running at 2.8/3.0, no matter what is going on... POTATO!
Truconcept Posted December 22, 2012 Report Posted December 22, 2012 u could at least take the panel off and see if theres a dust build up **actin bad like a kid at six flags**
iceman1575 Posted December 22, 2012 Author Report Posted December 22, 2012 u could at least take the panel off and see if theres a dust build up Already did that when I replaced the thermal paste...Guess I'm just going to have to deal with a CPU that runs faster than it's supposed to, can't change it, and decides it wants to throttle down to 800mhz in the middle of a gunfight... POTATO!
beaker Posted December 23, 2012 Report Posted December 23, 2012 Turn speedstep off then, or you can set preformace states in the power settings in control panel.
