2 12" Kicker L7 and 15" Kicker L7
whotry
And the 12s are the 2 ohm dvc not sure on the year. I'm having a hard time wiring the speakers though. Right now i have one voice coil wired and have the other wires on the voice coil inning to the amp. If someone can lead me in how I can wire my subs to 1 ohm stable that would be much help
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Yeah your amp at best will be wired to 2 ohms so youll be seeing like 800rms total.
Get a box design on here from joe x or get the torres calculator.
Get specs like the ones i just gave you for those subs and they will hit, ive had them for a while.
I ran my l7 15" in 7net @37hz ,90sq" of port on 1k for nilly 1year till I sold it
It was a good setup for what it was
If you only have 1k of power run just the 15
If you can get something around 15-2k run the 2x 12" in 6net @33-42hz with 90sq" of port,
Now much space do you have to work with?
Rather you do the two 12's more cone area and just upgrade the amp if you have to but itll be better than the 1 15.
Hey teamace thanks for the link I'm
Having a little trouble understanding the image.
I have two +- +- on my amp.
Now do I run the wire to both subs then just connect one pos one neg to the amp.
Sorry I'm a bit confused
Exactly how it is pictured lol. Sorry i cant really make it easier.
what type of music do u lisson to?
you may not need it tunned so low
if you can seal off the recess and put sub port fwd and only use the larger this may work for you
5.7net@42
and if you want a lower tune add an L2 to the port 11" long for 5.2net@35hz
5.7net@42
Mostly rap and hip hop. Hey John is there any way you can make a box to fit in the small square corner then expand into the larger trunk area.my dem. are up there but I will upload a picture to show you how my trunk looks
  • Who's Online   0 Members, 0 Anonymous, 1737 Guests (See full list)
