1994 Deville, First system.
Just wanted to start off saying that Ive always watched and loved SMD's videos on youtube. The first time I saw the Tahoe I was amazed and always watched that same video. That was probably 3 or 4 years ago and finally I am old enough to have my own car. I got my car for free from my dad and we had to fix it up a bit for it to run. I just got a job a month ago and saved my money here and there. Christmas came along and I got some money. I managed to get 250 dollars and I decided to setup a system, In my 94 Cadillac Deville.
I bought 2 HFX12D4's. Which is 2 dual voice coil 12's at 4 ohms each. 400 rms 800 peak.
Also bought Crunch PZA2000.1. Which is 1 2000 watt peak amp. I was too stupid to remember to look for rms and ended up buying this.
Also bought a ported box tuned at 40 HZ
Had to buy a line output converter because changing the factory system would be more work than a normal car.
Heres some pictures of it
CAM00132.jpgsubs and amp before the box arrived
CAM00134.jpgThen the box arrived :)
CAM00137.jpgPicture I used to help me wire the subs to 1 ohm
CAM00138.jpgMy 8 gauge power wire I bought from lowes
CAM00153.jpgFuse
CAM00152.jpgWhole Engine area
CAM00154.jpgLine output converter I unplugged the 6x9 and wired it to the output convertor. The other wire below is the remote turn on
CAM00142.jpgAbove the subs Is where all this wiring is
CAM00143.jpgThen I ran the bass knob along with the power cable to the cab
CAM00149.jpgThis is where I put my bass knob
CAM00150.jpgHere is the knobCAM00151.jpgHeres how I drive around and keep it, When I leave my car I just push it into the little plastic area so no one can see the knob
CAM00141.jpgMy stereo :)
CAM00140.jpgHeres what my subs look like
CAM00144.jpgHeres my overall trunk
CAM00145.jpgI was satisfied with how loud it was. I felt pretty accomplished when I finished. Its pretty nice to say that I hooked this all up by myself as a 16 year old and that its my first system. My friends were impressed that I did it by myself and asked If I could do theirs instead of paying some guy to do it. Felt good to drive around and listen to music with my friends. Also I dont play music in neighborhoods or when im at a stoplight, Im not "that" kid.
you need bigger power wire
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
thats 8 gauge at the biggest. Id have 4 gauge.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Look at it this way, you are sucking a watermelon through a straw with that power wire. You will end up melting it and causing a fire if its not the correct size.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
i remember my first setup i had 2 runs of a 16 guage runing to my amp(terrible idea) toasted my sony xplod amp. you cant go wrong with bigger power and ground wire
08 Ford F150
that doesn't even look like 8 gauge. looks like 10 gauge.
use 4 gauge, or risk fire, basically.
I was planning for 4 gauge, but my step-dad insisted that 8 gauge was plenty big enough. I just said whatever, I just wanted to get it hooked up.
When I get some money I will see what I can do about the wiring.
  • Who's Online   0 Members, 0 Anonymous, 956 Guests (See full list)
