Fi SP4 d2 on 3k box advice
OrzechNJ
whats up
Im about to purchase the Fi SP4 15" and I think I should get Dual 1s but I just wanna make sure..
Im gonna run it on 3-3.5k at 1 ohm ..
i was gonna go with different brand but unfortunately, cant afford it
SP4 seems like a good sub for good price !
tell me your opinion and dont compare it with other subs since we dont wanna make vs thread..
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
one sub to one amp?? you need dual 2 to run it at 1ohm
audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
yea one sub to one amp.. the thing is that im not sure about the amp yet..
so If i wanna run it on one 3.5k I should get dual 2s and if I run it on 2x2ks I should get d1s?
It depends what you're wiring it to. if you want to wire it to 1 ohm, you want D2's. If you're wiring it to .5 or 2 ohms you'll want D1's. Depends on what the amp is stable down to or if you're strapping it.
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
yes, one 2k on each coil?? you would need the d1's
I won't recommend OP to wire at .5
I wouldn't recommend OP to wire at .5
Depends what amp he's running and what kind of electrical. I'm running a Planet Audio BB2400.1 at .7 on stock alt and 1 yellowtop in the back. Not smart, I know, but it has to do till I get new alt early january.
Neither do morons
I dont wanna run it on less than 1 ohm cause my electrical wouldnt be better than this
180 singer alt
d3400 under the hood
and before getting new amp I wanna get d3100 and prob another one later.
with 2 extra d3100 or xp3000 I be able to run 2x2ks on 1 ohm ?
