Fi SP4 d2 on 3k box advice
OrzechNJ
one sub to one amp?? you need dual 2 to run it at 1ohm
It depends what you're wiring it to. if you want to wire it to 1 ohm, you want D2's. If you're wiring it to .5 or 2 ohms you'll want D1's. Depends on what the amp is stable down to or if you're strapping it.
HUH? this thread is a clusterfuck.
2 amps to 2 subs. you want 1 ohm per amp. get d2 coils. parallel. done. end thread.
edit: 1 amp to 2 subs. 1 ohm. d1 coils. series parallel. end thread again.
I go with d2's on one 3k amp on 1 ohm..
just ordered 563.24 total ..
yes. ONE d2 sub parallel on ONE 3k amp will give you 1ohm.
from this I understood that I need Dual 2 coils to run it on single amp at 1ohm !!!!!!!!!!!!!!!!!!!!
yes, you got the right sub for one amp.
@ Kranny you misunderstood
d2's I meant Dual 2 coils no TWO DUAL 2 subs..
yes i did, sorry about that. generally when you plural something, you mean two, or many, of them. d2 already means dual 2. so you adding an apostrophe "s" makes it seem like you have two dual 2 woofers, not one.
yea Im still learning lol .. but thanks for help !!
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
are you fucking illiterate? good luck wiring to 1 ohm with 2 d2 woofers.
edit: hope to god "d2's" doesn't mean two d2 woofers. otherwise you just screwed yourself.
Ha...aha.... Too far lol
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
its gonna be a while till I get the sub but I already have to start thinking about the box design.. I will double check
but my dimensions are 17hx32wx20d
and after sub displacement it gives me 4.68 ft net with 6" diameter and 10" length tuned aero port to 33.63hz
or with slot port 3x15.5x20 with 4ft net tuned to 34.95
I dont give a fuck what people say about my english.. still learning and have to make mistakes
I didn't mean anything against you, I was just laughing at Kranny blasting off lol
Mechman 240a alt
