Okay I figured how to run my D2 subs at a 2 ohm load! But this only works on a mono amp "I think" I have a 2 channel amp can I just run my wire to the amp and just bridge it cause after you wire them to a 2 ohm load u end up with 2 single wires. So can I just run both subs of one channel or can I bridge it and use both channels? Take the hot and run it to one channel and the negative and run it to the other?
You won't be able to use your 2ch amp unless it is capable of running 2 ohm bridged, which there are very few made capable of running that low an impedance.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
O thank you! You was a lot of help! So I can just hook the negative wire into one of the slots and the positive wire wire into the other slot and it should work! So I don't have to worry about the other negative and positive terminal slots?
It sounded good
I had the gain low so my light wouldn't dim
How your electric?
I had stock electrical
Your definantly going to have to upgrade your electric
I had it hooked to an 18" sub check my buildlog link in sig it would flex a lil nothing huge but I wouldn't expect much on stock electrical
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
