OrzechNJ Posted January 2, 2013 Report Posted January 2, 2013 as the topic says.. I be running a pair on t600-4 , 360.2 is gonna do all crossovers .. I will get another pair in the future.. Just need to do some fiberglass work, its too cold now and I dont have a garage.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
OrzechNJ Posted January 3, 2013 Author Report Posted January 3, 2013 do u need some more info to answer this question ? im not sure which one i supposed to get.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
alaskanzx5 Posted January 8, 2013 Report Posted January 8, 2013 dont know the power handling of those tweets but what i do know is that the 2 8ohms would be wired at 4ohms assuming you are doing 2 on the left and 2 on the right either the front or rear channel. as in all 4 wired to the front or rear channel. not sure of the specs on that amp either but im assuming about 150rms at 2 ohms and 100 at 4ohm. if those have a power handling of under 75 i suggest the 8ohm. if they handle 75 or more then the 4ohm would work. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
