Go-N-Def Posted January 3, 2013 Report Posted January 3, 2013 A couple of weeks ago my batt died while I was out of town, so my mechanic came over to replace my batt. At the local auto part store the choices were store brand for $50,$70,$150 for the best I went with the optima for a few dallors more $200. At this point Im kinda pissed becuase I was donig my reserch on the xs batts. Question where should I go from here? My truck is 2003 ford explorer. 2600 watt on subs stock alt possi 130-140 amp. 1 Keep my yellow and add a yellow. 2 Put a red up front and move yellow to the back. 3 Get 1 big xs up front nothing in back. ( Prob only can afford 1) Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
DR.TINGTING!!! Posted January 3, 2013 Report Posted January 3, 2013 It sounds like that yellow top is fairly new I would imagine you could put a D3100 or similar batt in the back and get away with that without breaking anything. I have a yellow top just collecting dust because I didn't do research first also. Maybe take a look at crescendo's battery too it's pretty well priced if it really does what it says.
Tarball Posted January 3, 2013 Report Posted January 3, 2013 @ 2600 watts you are getting into H.O, alt territory. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
