loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 I tested my T1Ks at 1400watts & change @ 1ohm. I'll go ahead and predict a 138 from that setup. T1Ks can be picked up for around $250 used. When HDA gets goin again they'll have the factory refurbs for $300. An RF T1K will walk all over the over-rated Hifonics 1606. The 1606 is only good for around 1200watts. ok thanks a ton..=) Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
gotFI? Posted January 30, 2008 Report Share Posted January 30, 2008 ok, so i guess ill go with the lvl 4, i kno i shouldnt be too worried about db, but could i at least expect 130db with 1 lvl 4 15" and a t1k its really hard to say. its all in the type of car, box design, what its tuned to, and power. power is how you get loud. more power the better. i can bassrace a 146-47db's with my setup. check my sig. if i ran one LV 4, i could maybe get mid 130's. its all in the build. CLUE: tune it high 36-37 hz, you'll get your 130db's Quote Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 its really hard to say. its all in the type of car, box design, what its tuned to, and power. power is how you get loud. more power the better. i can bassrace a 146-47db's with my setup. check my sig. if i ran one LV 4, i could maybe get mid 130's. its all in the build. CLUE: tune it high 36-37 hz, you'll get your 130db's ok thanks a ton Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 ok thanks a ton one more thing on the t1k, i just have a stock deck right now, which i plan on keeping till i have 3grand for the double din i want, can i run that t1k off of the stock deck with high input or w/e its called, or is there any other way to hook it up, cause i kno it dosnt have rca's Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
Derrick824 Posted January 30, 2008 Report Share Posted January 30, 2008 one more thing on the t1k, i just have a stock deck right now, which i plan on keeping till i have 3grand for the double din i want, can i run that t1k off of the stock deck with high input or w/e its called, or is there any other way to hook it up, cause i kno it dosnt have rca's Get a Line Output Converter. I still use the stock setup in my Yukon with an LOC. Quote Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 Get a Line Output Converter. I still use the stock setup in my Yukon with an LOC. any specific place i have to get those? Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
Boon Posted January 30, 2008 Report Share Posted January 30, 2008 Depends enormously on stuff like car, box, whether it's music or a burp... In the right car tuned to like 55-60hz I wouldn't be surprised if you could crack a 140 with that setup on a burp. With music and a nice sounding box tuned lowish, probably do middleish 130's I expect? A little more power wouldn't hurt, maybe 2000wrms to allow a bit of sorta headroom (lol?) / anger for short periods/burps? Mind you it's not going to be quiet Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 Depends enormously on stuff like car, box, whether it's music or a burp... In the right car tuned to like 55-60hz I wouldn't be surprised if you could crack a 140 with that setup on a burp. With music and a nice sounding box tuned lowish, probably do middleish 130's I expect? A little more power wouldn't hurt, maybe 2000wrms to allow a bit of sorta headroom (lol?) / anger for short periods/burps? Mind you it's not going to be quiet i guess i shouldnt be too worried about the db as long as it pounds, i like bass, but i just dont have as much room for it as id like, so as long as its loud bein fed 1400 watt rms then im happy Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
Jman08 Posted January 30, 2008 Report Share Posted January 30, 2008 my birth sheet says 1423 @ 1 ohm im hookin it up tommorw i cant wait! Quote Youtube.com/J Hutch22 Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 my birth sheet says 1423 @ 1 ohm im hookin it up tommorw i cant wait! gonna b nice =) Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
