07 Fit - New Vid of the AB XFL15 flex on Pg 4
Great build!
Good call not doing the terminal cup, I've had those leak air and fail on me due to the terminals moving and shorting and just plain burning up from too much current. If you want a shade tree trick to get the most out of thin wire, strip both conductors like normal then twist them together to combine all the strands in both pieces of wire. Add up as many pieces as you want to get the desired gauge.
I'm gonna hate
Thanks for the comments guys.
I will be adding a larger amp soon to see how loud these Lanzars can get. I will then rock that setup for a short time until I can order some new subs. I have been eyeing the PSI Platform 1 18's, thinking about doing 3 in a wall or just a large box; not quite sure yet. I plan to do a couple competitions this summer and I know the Lanzars probably won't be up to the task, but I think 3 PSI 18's and 2-3k watts should get nasty.
If you want to do comps just remember that walling often places you in a walled class where from what I understand it is much harder to compete.
I'm gonna hate
Yea, that is usually the case which is why I am still trying to decide for sure. The only close competitons I've found so far are in Ohio and they allow walls in all classes except trunk class (which I couldn't get into anyway) so that is what made me consider just going ahead with a wall build. I am still not sure though, because if I find another competition it may stick me in a class with the real big dogs.
  • 4 weeks later...
Small update time.
I've just placed an order for more goods. I've got 20 more sq/ft of FatMat on the way (This will make a total of 50sq/ft) to finish off the hatch.
The best part is a new amp - MBQuart Onyx 1.1600. It's rated @ 1,100wrms @ 2ohms which is what I'll be running it at for now but it does 1,600 @ 1 ohm so I'll configure it for that when I upgrade woofers down the road. It should really wake the 4 10's up even at 2 ohms. I will update with pics once I get it. I also grabbed a 2 gauge amp kit to give the new amp plenty of juice.
Sweet build man! Love the cone area in that fit :D
