07 Fit - New Vid of the AB XFL15 flex on Pg 4
You sure all of your subs are wired up correctly since switching over amps? Are all of your settings correct on the new amp? (xovers, etc...)
Just trying to come up with things- you know. I always mess up the simple stuff.
Build is coming along great!
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Amp is in and thus far I am completely underwhelmed for what should have been a nearly 3x increase in power @ 2 ohms. I am going to tinker a bit more and see what I can figure out. It's louder than the Fx1.400 but not as much as I'd expect at all.
IDK sometimes shit is weird that way...I had a crappy 10$ woofer(not subwoofer) in a tline on 15-20w in my truck for about 2 weeks...it was almost as loud at 40hz as my current T-line with Skar vvx10 and 400w....but the new one gets down to 20-25hz and kills lows for a single 10.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
You could have crossover messed up on the new amp and it would kill output..I have done that a few times when using a two channel and forget to take a look at the crossover if its on hpf or lpf and am too anxious to power it up and hear it.
Vehicles
2005 GMC Canyon
Sold to:
Sweet build man! Love the cone area in that fit :D
Thanks Carbon. I thought it was a lot of cone area at first, then I signed up here and looked at all the builds that dwarf mine. Now I just want lots more.
Thanks for the comments, I've figured out the issue and it was quite surprising. (I put details at the bottom)
Well that is certainly crazy, my 10's get fairly low but below 25hz drop off pretty hard. Maybe some day I'll try one of those crazy T line enclosures.
Thanks for posting the suggestions, it was none of the above though. Mostly because this amp has no crossover switches. It's just a mono sub amp with only a frequency range adjustment which I triple checked.
So what was it you all may wonder? The subs were not the OHM rating they were advertised as. I bought these 4 Lanzar MAX10D advertised as Dual 4 ohm, so you'd think that they would be 4 ohms per coil. Then when wired in series each woofer would be 8ohms then when you parallel all 4 together you'd have a 2 ohm final load - Nope... Not even freaking close. I metered the wires coming out of the box just for kicks and got roughly 6 ohms. I was thinking maybe I had some loose wires in the box so I pulled all 4 woofers and metered each coil - every single one measured about 7.8 - 7.9 ohms. WTF? So I went ahead and paralleled each woofer (which should have given me 4 ohms per woofer and a 1 ohm final load) and metered again - I got about 3.5 ohms final load after this which still doesn't make any freaking sense to me. It should be 1 ohm but I think something is strange about these woofers. Either way this tells me my old amp wasn't pushing but probably 100-150 watts at the most considering the 6 ohm load it saw. It was pretty damn loud for each woofer only get 30-35 watts rms though. Either way, this is as low as I can get it for now with these woofers considering it's all paralleled at this point.
I fell like a dumbass for never metering them from the get go but I guess live and learn - always meter your subs.
So onto the results, I just tried it with the car off for now and it was a MASSIVE difference even with the weak ass 3.5 ohm load - which this amp probably only makes like 600ish watts at. It still pounded like never before. I'll be beating down the block on my highway commute tomorrow for sure. This however makes me want new woofers sooner than later. Mainly so I can actually show the amp a 1 ohm load and see true power, as this 3.5 ohm stuff is for the birds. I'll be bringing my meter to work tomorrow to verify it's reading correctly by metering some various resistors that I know the rating of for sure.
It's a hell of a lot louder though and no fault of the amps, just the cheap Lanzar subs but what did I expect considering I got all 4 for $96. I think a trio of 18's are in the cards though for roughly 750" of cone area where as my 4 10's are only about 300". I may also do 4 15's - which is also about 700" of cone area. It depends what I can find and what fits the budget.
It was driving me nuts so I checked it again and this time got .8 ohms final load. Which is about right for 8 x 7.8-7.9 ohm coils all paralleled together. So either my meter is flaking out, the battery is dying and thus giving false readings or I just wasn't getting a good connection the first time. Either way, if the speakers were actually dual 4 ohm as advertised I'd be at .5 ohms with 8 coils in parallel not .8. So I'll try a new battery in it tomorrow and see if it makes any difference.
Update time, I got a bit of work done today. See pics for progress.
New amp next to old amp. MB quart ONX1.1600D on the left MB Quart FX1.400 on the right.
OEM ground spot next to battery. Sanded to bare metal.
4 gauge engine block to battery ground. You can see the OEM wiring which ground the engine block. I left it and added this 4 gauge to an empty bolt hole on the head. This is as close as I can get to grounding the alternator. I will be doing the positive feed from the alternator once I get some 0/1 and adding 0/1 grounds as well.
New 4 gauge battery to chassis ground added in conjunction with the OEM ground. It will be 0/1 eventually but I only had the 4 gauge to use for now.
2 gauge wire to amp connected to battery. I mistakenly had it on the lug to the right before this, I didn't realize it had an 80 amp fuse there. As you can see it's connected right to the battery now.
OEM battery (replacing with AGM soon) with new 2 gauge wire to amp and 2 new 4 gauge grounds.
Dirty engine bay with new 2g wiring to amp and new fuse holder. Also the 2 new 4 gauge grounds.
Well, I am a dumbass. I don't know what I was doing wrong the other day to get 7.9 ohms per coil but it wasn't right. I metered my box again and got the same .8 ohms but when I touch the probes together, I still get .3 ohms. So there is a little resistance in them. I loved how much power the amp was making at .5 but I didn't want to leave it like that due to it not being stable that low. So I pulled all 4 subs once again and checked each coil directly at the tinsel leads which got me about 4 ohms per coil, so the subs are correct. I wired each sub in series as I had it before and got about 8 ohms per sub, then paralleled them all and ended up at 2 ohms final load. So the amp won't make as much power but I'd rather play it safe. I'll eventually be upgrading anyway and will buy subs that give me a 1 ohm final load. Just finishing up the 2 gauge install today as well as some more sound deadening. More pics to come later.
I went ahead and pulled the back seats since I never use them anyway. I need more MDF to make a proper amp rack so it's just on basic amp board for now. I didn't bother making the wires pretty since I'll be getting MDF within the next week or two. This is what it's looking like for now.
MB Quart ONX1.1600D plus a Scosche Distribution block which I am merely using to monitor the amps voltage for now. It only has 100 amp fuses in it at the moment so I bypassed it for the time being. I did run some small wire direct from the amp power terminals though so I can watch voltage.
The subs now centered in the back. I can't tell if it made any difference yet really since I made a lot of other changes at the same time.
What is left after the rear view mirror falls off. I have remounted it for now but I may need to modify the way it mounts if it keeps falling off.
So that is the update for now.
