Box for level 2 10" help
Noel989
Thanks
I'll try to wrk with this cause I still about 2 more inches so my amp can sit their
Which if I extend it externally I'll keep the same volume but will lower the tuning a bit right?
If you give me your max dims you can work with in a way your amp fits I can change the above to what you need, just bear in mind that the port needs some free airspace in front of it (1 1/2" in this case) to work properly.
Max dimension
Lengt 25+ no more than 30
Width 12
Height 12
If you need to add more add to the width
And if you've seen the second picture I posted thats how I want to look
So the port has to extend 3" out so my amp can flushed mounted in their
Don't care if the amp is hanging out on the opposite of the port I can add more wood to make look goog
Max dimension
Width 12
Height 12
Ok so I changed the above so depth is below 12" since you apparently want to put the amp on the back of the box.
Max dimension
Width 12
Height 12
Not on the back
It will go infront were the port goes
The amp is 10" tall plus .75x2 for the wood thickness is 11.5" so 12" is good
Amp is 3" width so the port will extend 3" so it can sit their flush
Amp is 23" long, here if it has to be shorter or longer it doesnt matter cause I can add some wood to extend it according to how much the amp is sticking out
Most common aimings on your type of vehicle is port firing at the rear gate and sub firing also at the rear gate or port firing at the rear gate and sub firing up.
You cant do port/ sub on the same face if you are installing the amp there so where is the sub going to be?
I'm not
Port back sub up
I just need the port extended externally about 3-4 inches
  • Who's Online   0 Members, 0 Anonymous, 537 Guests (See full list)
