Noel989 Posted January 7, 2013 Report Posted January 7, 2013 I just download Torres Can someone double check the numbers or give me suggestions This for a level 2 10 Being powered by a dc 3.5k @4 ohms Dc site says 750 watts and the sub is rated 600watts These are the dimensions I used on Torres Height 11.5 Depth 11 Width 24 Those are not my max dimensions it's just what I use Here's a screen shot of it Were it says external port I put 3 inches cause I want it to extend it so I can mount the amp their This is going in a pt cruiser Build Log - http://www.stevemead...-cruiser-el-pt/
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 Here's a drawing of how I want ithope you guys can understand my hand drawings On the top view That's how it would look without the amp mounted Build Log - http://www.stevemead...-cruiser-el-pt/
CJ18 Posted January 7, 2013 Report Posted January 7, 2013 Needs more port area. try and get it to 1ft3 net and 14in2 of port
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 Do I just make the port a lil longer that will decrease the net volume and increase the port volume Right? Build Log - http://www.stevemead...-cruiser-el-pt/
CJ18 Posted January 7, 2013 Report Posted January 7, 2013 No you need more port area. That would be the actual port opening. You need to increase the port width.
Cox Posted January 7, 2013 Report Posted January 7, 2013 Also the port ratio is right on that line of being too high. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 O ok ima go make some changes And the ratio was the the closest I could make it same with tuning I would get like 100 hz lol Build Log - http://www.stevemead...-cruiser-el-pt/
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 So I tried your suggestions and couldnt achieve them Any suggestion on how to get their? Build Log - http://www.stevemead...-cruiser-el-pt/
Joe X Posted January 7, 2013 Report Posted January 7, 2013 So I tried your suggestions and couldnt achieve them Any suggestion on how to get their? Here is a suggestion, 15 square inches of port area: Enclosure Specifications: Fb = 36 Hz Vb = 1 ft^3 External Height = 11.5 in External Width = 27.25 in External Depth = 11 in Port Width = 1 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 25 x 10 Back = 27 1/4 x 10 Left & Right Sides: Side 1 = 9 1/2 x 10 Side 2 = 10 1/4 x 10 Top & Bottom = 27 1/4 x 11 L Port Internal Assembly Parts: Front to Back = 8 x 10 Extension = 16 x 10 Assembly guide (generic dimensions):
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 Thanks I'll try to wrk with this cause I still about 2 more inches so my amp can sit their Which if I extend it externally I'll keep the same volume but will lower the tuning a bit right? Build Log - http://www.stevemead...-cruiser-el-pt/
