mid and tweet placement.
alaskanzx5
could anyone give me an idea as how to place my mids and tweets in these door panels? the mids are 6.5" rf punch pro and the tweets are the rf punch pro tweets. i have already removed the cubby at the bottom of the door i know these are meant for sq but i still want to get the best out of them that i can with them still in the door. the issue im having is trying to find a way to keep the door handle while still placing the tweeter above the mid. where the speaker grill flattens out with the rest of the panel near the front is where the dash lines up with it. im thinking the mid in the bottom front cornor with the tweet above it to the left but i dont see a way of keeping the door handle then.
http://www.google.com/imgres?q=2003+focus+door+panel&hl=en&sa=X&tbo=d&biw=1600&bih=728&tbm=isch&tbnid=JbN384_hmeRFRM:&imgrefurl=http://gtcarlot.com/data/Ford/Focus/2003/716607/Door%2520Panel-56361850.html&docid=tcPJLJJbN__YSM&itg=1&imgurl=http://images.gtcarlot.com/pictures/56361849.jpg&w=1024&h=768&ei=StDrUIuNPOioigKygIHgCw&zoom=1&iact=hc&vpx=178&vpy=128&dur=12075&hovh=194&hovw=259&tx=191&ty=116&sig=113190999491535364589&page=1&tbnh=145&tbnw=192&start=0&ndsp=32&ved=1t:429,r:1,s:0,i:93
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
if only you had non power windows, just like my buddys zx3 perfect spot sitting there, but he runs coax lol
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
lool, even if i didnt have power windows the tweets wouldnt fit there. not much smaller then a 6.5 mid.
http://rockfordfosga...x?itemid=223203
was thinking of fitting them into the 2 vents closes to the door but i have no fiberglass work exp so im trying to find the best and easiest way to go about it. i know for sure i could getthem to fit with out touching the door handle with tweet lower then the mid but if i flip the mid and tweet around the mid is somewhat in the way of closing the door. as soon as i get my mids in im gonna try to figure it out and post pics of every possible way i can think of.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
maybe fiberglass them into the mirror piece above the door panel in the top corner, those would probably be cheap to buy a set and fiberglass those
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
power mirrows, cant... lol
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 941 Guests (See full list)
