HotRodHam Posted January 8, 2013 Report Posted January 8, 2013 So i'll give you guys the basics of what i have. R-com internet (horrible) but thats not the problem. netgear router wired connection (same problem when i use a wireless connection) HP Pavilion DV6 laptop AMD A6-3520M APU with Radeon HD GRaphics 1.5GHz 6GB ram 64-bit Operating System Running Windows 7 Ok now to the problem. randomly when im on the internet. i get a yellow triangle with an ! at my internet connection. it happens with a wired and wireless connection. if i unplug the ethernet and plug it back in it works fine. but when it happens wirelessly i have to restart my modem which is such a hassle. it doesn't happen to my roommates laptops or tablet. so i drew a blank. i have tried everything from setting static IPs on all the devices to reseting factory defaults on the router. so i need help cuz this is a pain in my arse EDIT: Debug error i get on reboot i forgot about [1227/221403:WARNING:dns_config_service_win.cc(481)] Failed to read DnsConfig. [1227/221414:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221416:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221420:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221422:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221424:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221427:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 Edit2: i flushed my DNS cache by going to command prompt n typing -ipconfig /flushdns- and there's a slight difference in speed. i think that was one problem. anything else like that i can do to possibly get the problem to stop? 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
zack_e89 Posted January 8, 2013 Report Posted January 8, 2013 Wow, that is EXACTLY what happens to me all the time at home, with the yellow triangle and everything. It's very annoying being a gamer and on the forum all the time. 97 Suburban 8 custom PSI Platform 3 18's
wellington Posted January 8, 2013 Report Posted January 8, 2013 Sounds like some network settings issue on the computer itself 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
HotRodHam Posted January 8, 2013 Author Report Posted January 8, 2013 im going to restart my computer. because i get a DNS error message in a notepad ill brb n post the error 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
zack_e89 Posted January 8, 2013 Report Posted January 8, 2013 So how do you know it's not the router? You've tried another? 97 Suburban 8 custom PSI Platform 3 18's
HotRodHam Posted January 8, 2013 Author Report Posted January 8, 2013 So how do you know it's not the router? You've tried another? because my roommate doesn't ever get disconnected.... this is the debug i get every time i reboot my laptop [1227/221403:WARNING:dns_config_service_win.cc(481)] Failed to read DnsConfig. [1227/221414:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221416:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221420:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221422:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221424:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 [1227/221427:ERROR:proxy_resolver_winhttp.cc(79)] WinHttpGetProxyForUrl failed: 12167 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
beaker Posted January 11, 2013 Report Posted January 11, 2013 Looks like you may have some malware that set a proxy. Check your IE connection settings and make sure all the boxes are unchecked under the connections tab, then click the LAN settings button at the bottom.
