Max1636 Posted January 9, 2013 Report Posted January 9, 2013 I'm planning out my new system, and rather than do what most do and build the audio part of the system before the electrical part I want to see what I can run with what I have now. This is the electrical I will have: 1 x 225 Amp Upgraded Alternator ($700+ To Upgrade Any Further) 1 x Optima YellowTop (750CCA, 55Ah) 2 x Delkor 8D-1300 (1300CCA, 200Ah Each) Total CCA = 3350 Total Ah = 455 Dual 0 Gauge Front to Back Big 3 Upgrade I need to be able to run about a 5000w RMS system at least for a pair of Fi SP4's. Being rated 3k RMS each 5000w RMS each would be the minimum. (Old Car) 1995 Volkswagon Golf MK3 2.0L: Fi SP4 18 On A DC Audio 3.5K In A PWK Box Hertz DSK 6" Speakers, Clarion HU 3x Fullriver 120aH AGM's, 225A Alt 2012 Subaru BRZ: Audison Prima APK 163 Bit One, Rockford Amps, Audison Sub
Watch the bass Posted January 9, 2013 Report Posted January 9, 2013 Daily driver or SPL car? "in the abundance of water, the fool is thirsty" Bob Marley
Max1636 Posted January 9, 2013 Author Report Posted January 9, 2013 Daily driver or SPL car? Daily Driver (Old Car) 1995 Volkswagon Golf MK3 2.0L: Fi SP4 18 On A DC Audio 3.5K In A PWK Box Hertz DSK 6" Speakers, Clarion HU 3x Fullriver 120aH AGM's, 225A Alt 2012 Subaru BRZ: Audison Prima APK 163 Bit One, Rockford Amps, Audison Sub
Watch the bass Posted January 9, 2013 Report Posted January 9, 2013 A Second H/O alt or switching out the old H/O against a stronger 300 and up H/O alt. A second alt would be expensive incase of the bracket what you need to install him. "in the abundance of water, the fool is thirsty" Bob Marley
Nate Futuristic Posted January 9, 2013 Report Posted January 9, 2013 Add another battery or two I've seen and heard people running 5k+ on stock alts with a big battery bank I assume you know what imp rise is so unless your getting 2 2500bdcp that will put out a constant 5k or a 6k+ you won't see a full 500a draw unless your wired under 1ohm What amp(s) you gonna run? down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
Max1636 Posted January 9, 2013 Author Report Posted January 9, 2013 Add another battery or two I've seen and heard people running 5k+ on stock alts with a big battery bank I assume you know what imp rise is so unless your getting 2 2500bdcp that will put out a constant 5k or a 6k+ you won't see a full 500a draw unless your wired under 1ohm What amp(s) you gonna run? Well it would be nice if I could run a Crescendo 5500 (Old Car) 1995 Volkswagon Golf MK3 2.0L: Fi SP4 18 On A DC Audio 3.5K In A PWK Box Hertz DSK 6" Speakers, Clarion HU 3x Fullriver 120aH AGM's, 225A Alt 2012 Subaru BRZ: Audison Prima APK 163 Bit One, Rockford Amps, Audison Sub
Nate Futuristic Posted January 9, 2013 Report Posted January 9, 2013 Add another battery or two I've seen and heard people running 5k+ on stock alts with a big battery bank I assume you know what imp rise is so unless your getting 2 2500bdcp that will put out a constant 5k or a 6k+ you won't see a full 500a draw unless your wired under 1ohm What amp(s) you gonna run? Well it would be nice if I could run a Crescendo 5500 Well a bigger alt will help... Its up to you if you already have a newer h/o alt is say just keep adding batteries until your voltage is to your liking.. I plan on running a 3500.1 v2 @ half ohm With a 240 a alt 3 d975s and a d3400 upfront with a few runs of 1/0 With the aq90x4 and the 3500.1 I'm expecting close to 500a down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
IndianaBassHead Posted January 9, 2013 Report Posted January 9, 2013 With 1-2 more of the 210 ah batteries you should be fine while reving. But at idle, I'd say you will run into some problems. Also a ballsy move running lead acid batteries in the back. Audio Build Ride: 2002 Chevy Blazer 4 door Head Unit: Pioneer deh-80prs Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2) Mids/Highs Amp: Skar 85.4 Mids/Highs: Skar components Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31 Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/ Perfomance Build 2003 Nissan 350z Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU Exedy Racing Clutch, Built Motor by Racing Innovations Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels 466rwhp Bike 2008 Midnight Blue Kawasaki ZX-14 Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
Max1636 Posted January 9, 2013 Author Report Posted January 9, 2013 Should I be expecting more output from these batteries than 1300 CCA? Each battery weighs 60kg (Old Car) 1995 Volkswagon Golf MK3 2.0L: Fi SP4 18 On A DC Audio 3.5K In A PWK Box Hertz DSK 6" Speakers, Clarion HU 3x Fullriver 120aH AGM's, 225A Alt 2012 Subaru BRZ: Audison Prima APK 163 Bit One, Rockford Amps, Audison Sub
Max1636 Posted January 9, 2013 Author Report Posted January 9, 2013 With 1-2 more of the 210 ah batteries you should be fine while reving. But at idle, I'd say you will run into some problems. Also a ballsy move running lead acid batteries in the back. They are Calcium batteries, they only gas if they are overcharged. (Old Car) 1995 Volkswagon Golf MK3 2.0L: Fi SP4 18 On A DC Audio 3.5K In A PWK Box Hertz DSK 6" Speakers, Clarion HU 3x Fullriver 120aH AGM's, 225A Alt 2012 Subaru BRZ: Audison Prima APK 163 Bit One, Rockford Amps, Audison Sub
