In my old car yes there was actually since you are only going to need like 15 to 20 ft of wire per run and that wire sale was for 100 ft of wire i would just run the extra
ok, if i run that xtra, do i still need to ground to the frame? and since im using the xtra battery back there should i just run my amps off that one? and another stupid question, when i connect it to the battery, that battery and alt is gonna charge the other battery right? i dont need to do anything else then run power and ground
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
some people prefer to ground the back battery to the frame even after a negative run from the front battery ....... let's just say it's extra grounding. as for your amps ..... yes run them of the back battery. as far as charging the back battery, both front and back will be charged while our vehicle is running.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
ok, sounds simple enuf, thanks
My F-150 Build
  • Who's Online   1 Member, 0 Anonymous, 1681 Guests (See full list)
