2013 Hifonics BRZ Line
iwannabeloud
As a matter of fact yes but not my personal amp,it was a couple of friends that had them. Then I showed them what true rms was about with a RF P1000.1bd
How did you show them true rms? Did it maybe go like you telling your friends your amp sucks mines better RF P1000.1bd FTMFW.LOL
um no I didn't bash his amp,I clamped them smartass.
and what was the price per watt per your clamped results?
Not that I don't believe you but carry on.
my only issue with hifonics is. market it for what it is
i would buy the amps if the brx2400 was actually sold as a 1800 watt amp at 12 volts
then the brz2400 should really be called brz1800
Just sone thibgs to add.
1. Why the fuck is ur volts at 12? U guys bitch to no fuckib g end keep ur volts up anything more than 1v is the end of the damn world. I swear all I hear.
2. 12v would mean ur running basically with car off or ur electical is shit so u should spend more to beef that up. So to me rating at anythibg under like 13.5 is not worth shit on this forum when its all keep ur volts up don't let them drop.
Just stay off the thread if ur gonna bash on BRAND NEW PRODUCTS THAT HAVEN'T EVEN BEEN TESTED YET!!!!
But forreal where can u find a NEW amp that does close to 1700w for $160 or something? Not anything underground that's for damn sure.
They are great budget amps leave it at that.
Ok rant over.
whooo!!!.. i would rather buy an amp that will do rated at 12 volts than a amp thats rated at 14.4 volts..
1 the amp rated at 12 volts will put out even more power at 14.4 volts
2 the amp rated at 14.4 will not perform to its rating due to you will get somewhat of a drop regardless
just because we say an amp is rated at 12 volts it dont mean we run them at 12 volts get your shit straighten before talking shit
and for real im saying for personal use i had with the amp and if you read my fucking post right you will see i said BRZ the fucking old amp.. never did i say the BRX which i have never tried so why would i bash the new one
edit: Custom ported box designed by 412 CVX that explains your knowledge, hope you moved the port on that box
I found this in the meme thread:
picard-facepalm.jpg?1240934151
2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz
guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
Umm the talking shit was to everyone but regardless how how u stupid mfers talking u do run ur amps at 12v or u wouldn't fucking bring in this bullshit about it does blah fucking blah at 12v if its a 14.4v rated amp. Wasn't mafe to put out rated at 12 so its irrelevant. NOBODY GIVES A FUCK WHAT IT DOES AT 12V! IT SHOULDNT BE THAT LOW TO START... and ill ignore tha 412 comment. I am very pleased with my box. Not many other ways to design it. And I doubt u have all the info that happened with episode too. So just stfu. K. Thanks.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Ok rant over.
One thing, the only difference in the two imaginary amps you've just listed is the damn rating. It won't do more power than the 14v rated amp because they're the same amp. Why do you think so many amps share the same Korean board? The biggest difference in most of those variations of internals is the MANUFACTURERS RATING.
Yeah, you'll have the satisfaction of thinking that your amp is doing way over what it's rated, but at the end of the day, it's the the same shit.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Just daying wasn't it tony d or snafu saying that how we clamp isn't really accurate? U need more gear than what we have and a non reactive load if u truly are clamping them cuz it can change if u have a sub hooked up or something...
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
no we are saying they are rated at 12 volts because thats what the company tested at.. i voltage stay at 13.8 to 13.7
when you buy a fosgate it is rated at 2500 at 12 volts because it was tested at that voltage.. when you open the box you will see the test they do at 14 volts and you will see it makes about 700 watts more, to around 3200 watts.. thats the difference we are talking about. you will be lucky to get 1700 watts from the BRZ2400
At what voltage tho? People have claimed close to rated around 14v. At 12v its that because they weren't rated at that to start.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
lets put it this way they are both run at 14 volts and you have a stealth electrical and get no voltage drop
lets say the brutus does do rated power at 1ohm.. after rise it goes down to maybe and lets say 1800 watts
the fosgate at 3200 watts after rise you will see close to rated maybe 2200 watts thats a big difference and if you get the bdcp line you can get even more power
  • Who's Online   0 Members, 0 Anonymous, 1467 Guests (See full list)
