Meade Hide Question
Meade what's up man, it's Houston, I haven't heard from you in about a month, just shit we've all been busy anyway I got a little question that I thought of last night because I was planning my wire run out. The multi runs of 0/1 gauge that you ran in the Hoe, how do you go about feeding it into the Interior. because that shit not going under the carpet in the Yukon I can already tell you that. Did you just pre-drill you a big ass hole, HAHA, or what? Get back to me man!
I have this dream of this underground culture in mind, coming to life through the Audio that I build, Deep Perfection.YUKON'S SITEhttp://www.cardomain.com/ride/2397609
of course I aint Steve but u can do it like how he did in his Honda. Especially with multiple runs its almost a must that u run it under the truck or car. U can cut about a 3" hole right behind the rear seat or somewhere near where ur batteries are going to be and use a rubber wire grommet like the factory ones that are in your door jams. Try to find u one thats goes in about a 3 -4" hole put that in the whole to keep water and air from getting through and just poke a hole in it for each wire and pull each wire through 1 at a time; that way it fits snug around the wire and u wont have any leaks. once uve finished u might wanna go around the edge of the grommet with some black caulk to help keep it sealed. and ur set. Im sure Steve would tell u da same thing , go look at how he ran his wire in his honda.....its gives u a visual of what Im talking about
00114-1.jpgTEAM MechMan Alternators
the Tahoe is done much the same way but not nearly as clean as the honda.  There is also 5 runs 1/0 pos, 5 1/0 neg so its much more.  The Hoe has a nice spot on the driver side to run multiple runs right by the frame but its up to you where you want to come into the truck at.  You will need to make a hole big enough of course and it might be painful to do it to your ride but if you want big wires you gotta do what you gotta do ;)
Follow my Tweet (Twitter)
Preach on there, master teacher of the audio arts. I actually want to be able to see the runs nice and neatly tied, so now to have that 100% show car look, but to have it more looking like it's in the testing faze. My back panels are halfed so I get to take the bottom part out to make a good battery holder and then fiber glass them in there, who knows what I'll do.
  • Who's Online   1 Member, 0 Anonymous, 792 Guests (See full list)
