Rockford96 Posted January 16, 2013 Report Posted January 16, 2013 In torres my box is 2.4 net after woffer,bracing and port but my port area is 22sq in its for 3 tens on low power and they call for . 7-1.1 ported so i want to ask before i port it i am guessing i need around 27sq in of port would that be good im still new to box building im gonna be using pvc ports and i can have them sticking about 2in outside of the box if that helps My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Spencer Good Posted January 16, 2013 Report Posted January 16, 2013 You would use whatever they recommend, actually. You don't have to multiply it by the number of subs. 2012 TORed Challenger 4 Alpine Type-R 10 1 Brutus 2400.1 20' Knu 1/0 OFC 1 XS Power D1200
alaskanzx5 Posted January 16, 2013 Report Posted January 16, 2013 sounds kinda like you saying you want to port a sealed box. besides for 3 tens you want about 3cuft after displacement with roughly 32sq" of port. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
bkolfo4 Posted January 16, 2013 Report Posted January 16, 2013 You would use whatever they recommend, actually. You don't have to multiply it by the number of subs. Maybe I am not following your logic or what you are trying to say, but if you are going to go off of the manufactures recommended box specs for the sub, then yes you do need to triple the recommended volume and amount of port area if you have three subs. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Rockford96 Posted January 16, 2013 Author Report Posted January 16, 2013 sounds kinda like you saying you want to port a sealed box. besides for 3 tens you want about 3cuft after displacement with roughly 32sq" of port. i built the box planning to port it after displacement still sealed its 2.7 cubic ft and he minimun portedbox the subs call for is .7 so thats 2.1 cubic ft and for that i was askin would around 28-30 sq in of port be ok? My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
97_eldo Posted January 16, 2013 Report Posted January 16, 2013 12 to 16 square inch per cubic foot is the usual recommendation for port area iirc therefore 2.7 x 12 = 32.4 sq in 2.7 x 16 = 43.2 sq in based on the recommendations you are a lil small, it may very well work as is as nothing is a definate and it all comes down to what you prefer when it comes to the sound mentally unstable but otherwise just messed up
Spencer Good Posted January 16, 2013 Report Posted January 16, 2013 You would use whatever they recommend, actually. You don't have to multiply it by the number of subs. Maybe I am not following your logic or what you are trying to say, but if you are going to go off of the manufactures recommended box specs for the sub, then yes you do need to triple the recommended volume and amount of port area if you have three subs. No, what I was saying is say the manufacturer says the sub performs best at 11^2 port area per foot, 3 subs it's still going to be 11^2 port area per foot.I suppose I read his original post a little wrong, whoops. 2012 TORed Challenger 4 Alpine Type-R 10 1 Brutus 2400.1 20' Knu 1/0 OFC 1 XS Power D1200
bkolfo4 Posted January 16, 2013 Report Posted January 16, 2013 I see what you are saying now I dream of some day living in a world where people will quit relating port area to box volume (since they are not related), and actually size the port based on the subwoofer being used and the tuning frequency. . . Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
97_eldo Posted January 17, 2013 Report Posted January 17, 2013 so u say there is no recommended port area per cube ratio ? mentally unstable but otherwise just messed up
Spencer Good Posted January 17, 2013 Report Posted January 17, 2013 I see what you are saying now I dream of some day living in a world where people will quit relating port area to box volume (since they are not related), and actually size the port based on the subwoofer being used and the tuning frequency. . . so u say there is no recommended port area per cube ratio ? No, what we are saying is that the size of the subwoofer, and the size of the box are all irrelevant if you are building a box just in general for that size subwoofer. You need to build specifically around the subwoofer(s) you are using. 2012 TORed Challenger 4 Alpine Type-R 10 1 Brutus 2400.1 20' Knu 1/0 OFC 1 XS Power D1200
