vw passat Posted January 16, 2013 Report Posted January 16, 2013 hi guys if im going to make 2 aero port of 6'' each i need to add some displacement for them? tx guys
Jessica Posted January 16, 2013 Report Posted January 16, 2013 pi*r2 * length Only figure length to whatver is inside the enclosure, if you have external port it doesnt count towards displacement. 3.1415 * (3^2) 28.27 cuin per inch of port per aero port doesnt factor in thickness of port wall but will be close enough. edit i think the wall are 3/16" thick or something so you could convert that to decimal and then do the math if you want to get perfect. The flared end will be just a bit more displacement than the tube but not enought to really worrry about. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
tacomaguy1 Posted January 16, 2013 Report Posted January 16, 2013 Displacement is what he said then divided by 1728 So a 6" Aero that's 10" long 3.14 x 9 x 10= 282.6 282.6/1728 =.16 cuft for displacement I think lol Team Flex Issues
vw passat Posted January 16, 2013 Author Report Posted January 16, 2013 so for 2 6'' port i need .16ft^3 displacement? tx guys
tacomaguy1 Posted January 16, 2013 Report Posted January 16, 2013 No, I was using that as an example Its going to be different depending on the length. Longer will have more displacement and shorter will have less Team Flex Issues
vw passat Posted January 16, 2013 Author Report Posted January 16, 2013 i didnt understand how it works for the displacement so i need 2 6'' port 13'' long how much i need displacement?
vw passat Posted January 17, 2013 Author Report Posted January 17, 2013 someone help me pls i need to know for 2 6'' port how many displacement i need in ft^3? tx guys
tacomaguy1 Posted January 17, 2013 Report Posted January 17, 2013 About .45 for both Team Flex Issues
TheBetterMethod Posted January 17, 2013 Report Posted January 17, 2013 .42 2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3 The first build>>> http://www.stevemead...-outback-build/ 140.9 @ 36hz Sealed on dash! REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
