03 Xtreme Fosgate Posted January 18, 2013 Report Posted January 18, 2013 I would get a bigger iso being that you're running a crescendo 2k but if you have 2 yellow tops then you won't need an iso BUILD LOG-http://www.stevemeadedesigns.com/board/topic/179004-03-s10-xtreme-ext-cab-rf-build/ PHOTOBUCKET- http://s1354.beta.photobucket.com/user/03XtremeFosgate/library/truck%20audio%20rebuild
djscrappydee Posted January 18, 2013 Author Report Posted January 18, 2013 That's what I'm thinking about doing. I wish I wouldnt have bought them 20" rims lol (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
taylorpro Posted January 18, 2013 Report Posted January 18, 2013 Jesus you don't need a damn isolator.lol. everyone acts like hooking up two different brand batteries will kill the better of the batteries. If that were the case, then even if you hooked up two of the same brand battery, the stronger one would be killed by the weaker one. Which, has SOME SMALL amounts of truth to it IF one battery was drastically weaker than the other. BUT if you actually take care of these batteries like you're supposed to, and put them on a charger frequently and not rely on your alternator both batteries will last tons of time. That $80 you would spend on that isolator will buy you a good AGM battery charger that you can use to keep your batteries in as best shape as possible. Look at any of the big build's with batteries in the back... none have isolators 1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
djscrappydee Posted January 18, 2013 Author Report Posted January 18, 2013 I've never charged my yellow top battery lol had this mother fucker forever (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
Casket Posted January 18, 2013 Report Posted January 18, 2013 Jesus you don't need a damn isolator.lol. everyone acts like hooking up two different brand batteries will kill the better of the batteries. If that were the case, then even if you hooked up two of the same brand battery, the stronger one would be killed by the weaker one. Which, has SOME SMALL amounts of truth to it IF one battery was drastically weaker than the other. BUT if you actually take care of these batteries like you're supposed to, and put them on a charger frequently and not rely on your alternator both batteries will last tons of time. That $80 you would spend on that isolator will buy you a good AGM battery charger that you can use to keep your batteries in as best shape as possible. Look at any of the big build's with batteries in the back... none have isolators This ^^ If you run a wet cell up front and an AGM in the back , use an isolator. If you park and play without the car running and your worried about draining your starting battery, use an isolator. Kenwood KIV-701Crescendo BC2000DDC Audio lvl3 w/ lvl4 upgrade, 18''6ft^3 @ 27hzMBquart ONX 4.125(2) PWX 6.5 (2) PWX 8(2) FT1300amp Singer with VCM @14.5Optima YT & D1200My Build Log every company has their niche market. hifonics has successfully captured the average ignorant teenage boy. Dont trip.. Ive never won anything in my life. Spite a 10lb cock and a bucket of balls at birth,......Yeah.. like i said, nothing in my life. meh, im cool with it, fuck it.
djscrappydee Posted January 18, 2013 Author Report Posted January 18, 2013 Hell I'm confused I don't no what to buy now lol (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
03 Xtreme Fosgate Posted January 18, 2013 Report Posted January 18, 2013 Jesus you don't need a damn isolator.lol. everyone acts like hooking up two different brand batteries will kill the better of the batteries. If that were the case, then even if you hooked up two of the same brand battery, the stronger one would be killed by the weaker one. Which, has SOME SMALL amounts of truth to it IF one battery was drastically weaker than the other. BUT if you actually take care of these batteries like you're supposed to, and put them on a charger frequently and not rely on your alternator both batteries will last tons of time. That $80 you would spend on that isolator will buy you a good AGM battery charger that you can use to keep your batteries in as best shape as possible. Look at any of the big build's with batteries in the back... none have isolators some of what you said might be true but those big builds also have same brand batteries with similar specs. and FYI I do have a Ctek multi us 702 agm charger and had my yellow top for 5 years now BUILD LOG-http://www.stevemeadedesigns.com/board/topic/179004-03-s10-xtreme-ext-cab-rf-build/ PHOTOBUCKET- http://s1354.beta.photobucket.com/user/03XtremeFosgate/library/truck%20audio%20rebuild
djscrappydee Posted January 18, 2013 Author Report Posted January 18, 2013 I've had mine for like 12 years hahah (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
03 Xtreme Fosgate Posted January 18, 2013 Report Posted January 18, 2013 I've had mine for like 12 years hahah nice BUILD LOG-http://www.stevemeadedesigns.com/board/topic/179004-03-s10-xtreme-ext-cab-rf-build/ PHOTOBUCKET- http://s1354.beta.photobucket.com/user/03XtremeFosgate/library/truck%20audio%20rebuild
taylorpro Posted January 18, 2013 Report Posted January 18, 2013 I've never charged my yellow top battery lol had this mother fucker forever That in itself is bad for the life of the battery. Literally, if you had the means to do so, it's not a bad idea to charge them every single day. some of what you said might be true but those big builds also have same brand batteries with similar specs. and FYI I do have a Ctek multi us 702 agm charger and had my yellow top for 5 years now IT DOESNT MATTER.lol. in terms of a chemical construction every battery is the same. They have lead in them. They have a case and Mat with absorbed acid in it. They all function the same. The only difference is the quality of construction and materials used. WHICH, is the same thing as saying you have one weak yellow top and one brand new one, for example. the brand new one would yield some of it's voltage to the weaker one to equalize the load. If you were to charge each battery regularly, than the effect of the batteries on each other would be minimum to none. 1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
