DubNDodge Posted January 17, 2013 Report Posted January 17, 2013 I am not exactly sure of what hardware would be needed for the battery when used in the trunk. Just for a quick test I used a bunch of washers so that I could tighten the ring terminal down so it would be snug. Because without the washers, there was a good sized gap once the bolt as tightened all the way down. Is it supposed to be this or this. Also, while I'm asking questions, would the 551 work on any XS battery? Quote '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Nathan @ XSpower Posted January 17, 2013 Report Posted January 17, 2013 (edited) If you have some gap the washers would be fine. Most cases after you stack your ring terminals everything should tighten up though. Edited January 17, 2013 by Nathan@XSPOWER Quote
DubNDodge Posted January 17, 2013 Author Report Posted January 17, 2013 Thanks, I didn't know what was the "proper" way to handle that situation Quote '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
