RCA outputs grounding??
hello everyone i was just wondering IF i cant find out why i keep gettin engine rpms noise threw my speakers (that winey noise that varies with engine rpm) can i just ground my rcas on the back of my pioneer deck (its brand new) would it mess up my deck??? or blow the pico fuse or whatever it is its not blown like i said deck is brand new or anything else??? amp or amps heres a pic of how i did it im still gonna re-ground my deck to see if that helps (im still using the factory radio harness ground ANY SUGGESTIONS??
im running zero gauge from the ground on the battery to the trunk and into a distribution block to go to my amps
Yes, that can help. But it is also not a guarantee.
I say do it. And make sure your RCAs are kept as far away from the power wire as possible. And make sure all your grounds/connections are clean, tight, and secure
yeah my rcas are on the opp. side from the power wires this car has been a nightmare with the audio also the big 3 is all done in zero gauge
my amp grounds are from the amps to a (distribution block in the trunk) and from there to the main battery negative ran in zero gauge
Also make sure that you ground your head unit case if you haven't done so already
what do u mean??
ground the head unit case so i do this and should i run it to the same ground as where the headunit wire harness is being grounded right???
  • Who's Online   0 Members, 0 Anonymous, 976 Guests (See full list)
