Need your opinion on subs.....please
tlsrcs
so right now i have one 10w6 jl Sub running off of about 200w at 4ohms. It sounds good but not crazy loud. it can barley be herd outside of the truck. its a single cab and its between the two seats firing straight up. i was wondering if buying a bigger amp would make it pound harder? Or option b would be keep the same amp for now and get a sundown E8V2D2 then eventually get one or two more and a bigger amp....does anyone have a suggestion on what to do to get my truck to POUND with what i can DO?
what kind of enclosure are you using?
Hammerdown... 1%
right now its in a kicker bass tube lol...i know its not awsome i just want to get my subs figured out then i am going to fiberglass a center console ingratiating the sub/s into it.
?so i guess to add to the question i will build the console to the spec of the subs. but do you guys suggest ported, sealed or mounted upside down?
if it were me personally, i would just drop a skar ivx10 in the box on the same amp and call it a day.
Owner of BigAss Ports
Ported definitely ported it of course if you can fit it. What's your dimensions you can fit?
2003 f150, 2 ab hd 15 on brutus 2400.1, kinetik batt, big 3, knu wire, image dynamics cxs 6.5 with ppi tweets, pioneer 1din and clarion eq.
how come you WANT to be heard outside your truck? you should be happy about how it sounds when you're on the inside, not the outside.
everybodys definition of "pound" etc, is different. for me personally, you'd have to be in the 150's for me to think its "loud". a guy down the street may think a single 8 on 100w is loud.
Get a better enclosure and eventually buy a better/stronger amplifier and if you're still not satisfied, buy another subwoofer. I have a 1,000 W RMS @ 2 OHM amp laying around PM me if you're intrested.
just another sig.
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
